Cackling Chick
I LOVE ROCKS! πππ»πͺ¨βοΈ
Member since March 2022
Post by Cackling Chick on Apr 17, 2022 0:19:26 GMT -5
Newbie here and haven't tumbled yet but now have my rotary, assorted grits and ceramic media in 3 sizes. I'm an organization freak, so want to know the best way to store each of these to avoid spillage and/or contamination. Also, I live in a VERY dusty area.
What kind of containers do you store yours in? Can I use washed coffee cans with their plastic lids or...?
nursetumbler
Member since February 2022
Post by nursetumbler on Apr 17, 2022 0:52:40 GMT -5
Newbie here and haven't tumbled yet but now have my rotary, assorted grits and ceramic media in 3 sizes. I'm an organization freak, so want to know the best way to store each of these to avoid spillage and/or contamination. Also, I live in a VERY dusty area. What kind of containers do you store yours in? Can I use washed coffee cans with their plastic lids or...? Cackling ChickI bought containers from Walmart. They are square with a white twist top. I wish I could go out and take a photo but its dark. If you can wait until tomorrow I will get a photo of it for you as well as the lable. Suggestion, get yourself measuring spoons from dollar tree dedicated to that specific grit, less chance of contamination
Cackling Chick
Post by Cackling Chick on Apr 17, 2022 9:09:33 GMT -5
nursetumbler Awesome! That would be great to see a pic of the containers when you have time. Thanks!!
nursetumbler
Post by nursetumbler on Apr 17, 2022 13:36:45 GMT -5
Post by rmf on Apr 17, 2022 14:23:24 GMT -5
Washed coffee cans are good. I use a lot of Hilshire Farm deli slice ham boxes. they have a lid so when I get a customer their order goes in one and on goes the lid and I take it up and down from shop to kitchen as needed no dropped parts. They are big enough to hold all the parts and dopped stones. I like cheap and in this case recycled. I also recycle cardboard soft drink flats for rocks. We double them and they weigh a 1/2" so if you need to weigh for inventory weigh flat and all and the spreadsheets takes of the cardboard weight automatically. So what ever is cheap and convenient.
Post by perkins17 on Apr 17, 2022 14:56:43 GMT -5
I use wide mouth glass jars that I got at a yard sale. Plastic would probably be better because I know what it's like to be salvaging grit from bits of glass on the ground. Coffee cans would work just fine as long as they won't fall apart with use.
Cackling Chick
Post by Cackling Chick on Apr 17, 2022 15:17:28 GMT -5
nursetumbler Thank you SO much for the pictures and sense of what they can hold. I'm a bit confused though about the polish and pre-polish filling those containers, when the coarser grits don't come close to doing so. Especially since you said all amounts are 5lbs. each, which is exactly what I just received from Rock Shed P.S. I have more wrinkles than you. I definitely have "worker" hands. π
Cackling Chick
Post by Cackling Chick on Apr 17, 2022 15:23:14 GMT -5
rmf BRILLIANT!! Totally using your cardboard pop flat idea. Thanks!
Cackling Chick
Post by Cackling Chick on Apr 17, 2022 15:24:40 GMT -5
perkins17 It wouldn't have occurred to me that grit would stick to glass more than plastic, but good to know! Yes, I can see the plastic coffee can lids failing over time, but replaceable as I love coffee!!
nursetumbler
Post by nursetumbler on Apr 17, 2022 15:59:50 GMT -5
nursetumbler Thank you SO much for the pictures and sense of what they can hold. I'm a bit confused though about the polish and pre-polish filling those containers, when the coarser grits don't come close to doing so. Especially since you said all amounts are 5lbs. each, which is exactly what I just received from Rock Shed P.S. I have more wrinkles than you. I definitely have "worker" hands. π The finer grit weighs less than the same amount of coarser grit so it takes more polish grit to weigh the same as the coarser grit. Just like "whats heavier a ton of rock or a ton of feathers? Weight wise they are the same but takes a lot more feathers to make that ton. Does that make sense? I confused myself lol
Cackling Chick
Post by Cackling Chick on Apr 17, 2022 16:30:08 GMT -5
nursetumbler ah, logical! Learn something new every day. Thank you!!
cina
Member since December 2021
Post by cina on Apr 19, 2022 13:33:03 GMT -5
This is only like my second post here, but I wanted to share an awesome new grit container I discovered. My son's empty formula containers! They even come with a scoop and a place to hold it.
CLErocks
Member since October 2021
Post by CLErocks on Apr 19, 2022 14:54:25 GMT -5
I love my glass jars! From Target or Meijerβ¦ (sorry theyβre filthy, just finished a major round of construction) altoids tin & Lortone 33b for size correlation.
Cackling Chick
Post by Cackling Chick on Apr 19, 2022 20:48:39 GMT -5
Great containers you both have! I decide to recycle coffee cans as I like the wide opening.
Anybody know a good source for buying multiples of teaspoons and tablespoons w/o having to buy complete sets of measuring spoons?
dshanpnw
Member since December 2020
Post by dshanpnw on Apr 19, 2022 21:38:59 GMT -5
Oh boy, I have been using ziplock bags which work, but not as well as the ideas here. Time for a change. Thanks everyone.
Post by perkins17 on Apr 19, 2022 21:45:40 GMT -5
I love my glass jars! Β From Target or Meijerβ¦ (sorry theyβre filthy, just finished a major round of construction) altoids tin & Lortone 33b for size correlation.Β That's almost exactly what I have and use! I've dropped a glass jar full of grit before so just be careful if/when you are carrying it.
