Post by Pat on Apr 25, 2022 0:56:57 GMT -5
Post by vegasjames on Apr 25, 2022 1:27:38 GMT -5
Apparently you can't from here. Need to contact Proboards:
Post by Tommy on Apr 25, 2022 19:06:06 GMT -5
Apparently you can't from here. Need to contact Proboards: Yes - what James said. If you go in edit profile > privacy tab - you can choose to display your birthday or not but can't edit the date. I believe it's because it's part of the PG-13 enforcement when you first sign up. As a side note this is why the single most populated birthday among board members is 01/01/xx because a lot of people just want to blow past the field.
