phixer
Member since January 2022
Post by phixer on Apr 28, 2022 8:21:14 GMT -5
Well I received the black acrylic sheets to make new lids for my 3 lbs barrels. I checked the wear on the original lids and was surprised at how much wear there was in just four months.
This is from using 120/220 SC only and the center at the dimple is less than 1mm thick.
So I made some new lids from black acrylic and I made them 112mm in diameter, the originals were 111mm.
These were cut on a low end laser cutter and I am testing them now.
I have one barrel with gravel filler with 120/220 SC and the other barrel with glass, red gravel and quartz with 60/90 SC.
The new lids fit much tighter than the originals and so far no leaks.
phixer
Post by phixer on Apr 29, 2022 19:26:50 GMT -5
Well so far these lids are working out well. Twice I’ve noticed the bottom of the barrel with the glass bulging so I burped it and still no leaks.
Nuggets
I LOVE ROCKS! 🙋🏼♀️🪨⛏️🔍😁
Member since March 2022
Post by Nuggets on Apr 29, 2022 20:15:18 GMT -5
Skillz! For which type of tumbler?
phixer
Post by phixer on Apr 30, 2022 6:06:12 GMT -5
Skillz! For which type of tumbler? The Thumler’s dual barrel A-R2, 3 pound barrels.
Time
Making something positive out of COVID restrictions by learning to create jewelry out of stones.
Member since September 2021
Post by Time on Apr 30, 2022 14:42:41 GMT -5
Great idea. I don’t have that type of equipment but that looks like an excellent way to reduce variable cost if you do.
phixer
Post by phixer on May 4, 2022 6:54:45 GMT -5
OK that batch, of glass and junk, is done and no leaks or blowouts. Looks like the new lids work great. Yipeeeeeeee!
