jpw
Member since December 2020
Post by jpw on May 21, 2022 12:33:53 GMT -5
My first sphere wasnt quite round, is this a first grind issue or preform? Thanks
Post by Starguy on May 23, 2022 21:20:14 GMT -5
Hi jpwWelcome to the forum. I don’t have a sphere grinder. Somebody will weigh in. Check back.
Post by DirtCleaner on May 30, 2022 8:41:51 GMT -5
Your preform is critical to letting it become round. Would you be able to post some pics of your sphere machine set up?
jpw
Post by jpw on Jul 14, 2022 10:20:29 GMT -5
Sorry, for the late reply. I have a HP low speed machine. I bought a box of preforms that weren't cut very well and I didn't check them on the first sphere. I recut the remaining ones and haven't had another issue. P.S. Dirtcleaner I love your youtube videos. Thanks, helped alot
Post by vegasjames on Jul 14, 2022 18:01:56 GMT -5
callmerob
I really like a dirt road
Member since September 2019
Post by callmerob on Aug 29, 2022 21:26:22 GMT -5
I'll bump a slow thread because I'm interested in it. And I'll echo DirtCleaner's request for pics. I really don't know what HP's machine looks like or how it is set up, so pics would be pretty cool. And how are you determining roundness? On my homemade toy machine I've found that too much grinding pressure or springs or bungees or gravity or whatever can encourage selective grinding of soft areas. Or the case where the rock is not uniform but nearly equally hard, there is a tendency to grind lobes into the sphere. It is a 3-headed machine, so maybe preferentially grinding a 3-lobed shape is understandable. So I measure the rock with calipers, find the high lobes, and grind them on the diamond wheel, then return to the sphere machine. For diametral tolerances I'm happy with plus/minus 0.010" which can't really be seen. So, yes, pics please. And DirtCleaner's mention of preform quality is spot on. It is tough to make a sphere from an egg. Or a 3" thunderegg - a hidden gas bubble, apparently filled with a deep blue agate, in basalt, covered in baked mud and gravel, shaped like a potato - a current project. Good luck with your spheres and HP machine.
