Post by Deleted on May 26, 2022 15:11:58 GMT -5
Post by jasoninsd on May 26, 2022 15:18:36 GMT -5
Way to go Ashley...and your "crew"! The kiddos had to have been excited to see those! A bunch of them turned out REALLY good!! Pretty cool mix you had running! *Nice pictures to boot!!
Post by Deleted on May 26, 2022 15:28:26 GMT -5
jasoninsdThank you Jason! They were really excited, if you look close enough you can see just how excited, notice all the finger prints lol.I think the green triangle aventurine would make a cool necklace. Maybe I’ll save that one for when I get around to trying my hand at wire wrapping. I get pretty inspiring to give it a go when I see your work, your very talented at wrapping!
Post by jasoninsd on May 26, 2022 15:32:03 GMT -5
jasoninsd Thank you Jason! They were really excited, if you look close enough you can see just how excited, notice all the finger prints lol.I think the green triangle aventurine would make a cool necklace. Maybe I’ll save that one for when I get around to trying my hand at wire wrapping. I get pretty inspiring to give it a go when I see your work, your very talented at wrapping! Ahhh...thanks. I'll be watching to see your wire-wrapping (when the time comes)! I'd like to see more people post some stuff they've been doing (or have done). - Speaking of which...I have a batch that needs to have their Liver of Sulphur bath so I can get them posted! LOL *Fingerprints....the bane of macro stone photography! LOL
Post by mohs on May 26, 2022 16:18:55 GMT -5
Those came out gneiss glad you took the extra steps To stoke the kids
I’m not tumbler Buute from what I read Nation Geo Need to bump up their game People got disappointing results And it geared towards kids That can be a bad start to a great hobby
Not sure what they can do ?
Tumbling is a long arduous process Mosiy
Post by Deleted on May 26, 2022 16:21:10 GMT -5
Thanks mohs it is disappointing. They should make the instructions different and not rush it. That would probably help.
electrocutus
Member since October 2020
Post by electrocutus on May 26, 2022 16:24:14 GMT -5
Great results, congratulations! The National Geographic Pro tumbler is actually quite good, but the quality of the grit is what lets people down. The main culprits are the "final" polish grit, which is too coarse to give you any kind of shine, and the rotating speed,which even at the lowest speed is too fast for fragile stones.
I find the quality of the barrel and lid of the National Geogrphic tumbler is actually better than my Lortone 33B barrels. Unfortunately, the Nat Geo barrel doesn't fit on my Lortone tumbler because its diameter is too big and it just sits on the frame above the rollers. I could probably modify the frame to make it fit :-)
I tend to use the Nat Geo for stages 1 and 2, and then the other stages go in the slower/rotating Lortone.
Post by Pat on May 26, 2022 16:41:52 GMT -5
ashley, if you hover over "mohs", it will reveal his real name, @edxxmost. I had to add the XX so it wouldn't revert to his avatar name. Many RTHlings have the same name forever, other RTHlings change frequently. The actual name is found by hoving over the one you see. Good luck! I'm not a tumbler, but you have a superb batch!
Post by Deleted on May 26, 2022 16:50:56 GMT -5
Thank you Pat ! And thanks for letting me know that, I updated it to tag him. That’s helpful.
Post by Deleted on May 26, 2022 16:54:00 GMT -5
Great results, congratulations! The National Geographic Pro tumbler is actually quite good, but the quality of the grit is what lets people down. The main culprits are the "final" polish grit, which is too coarse to give you any kind of shine, and the rotating speed,which even at the lowest speed is too fast for fragile stones. I find the quality of the barrel and lid of the National Geogrphic tumbler is actually better than my Lortone 33B barrels. Unfortunately, the Nat Geo barrel doesn't fit on my Lortone tumbler because its diameter is too big and it just sits on the frame above the rollers. I could probably modify the frame to make it fit :-) I tend to use the Nat Geo for stages 1 and 2, and then the other stages go in the slower/rotating Lortone. Your right it’s the grit! I figured the time for the 1st stage should be a bit longer too but not real sure. I really like the Nat Geo tumbler for rough. Will use it for the 60/90 SC then switch to the Lot O. I’m to impatient to go rotary the whole process.
rockbrain
Member since January 2022
Post by rockbrain on May 26, 2022 19:04:19 GMT -5
Nice job! Those came out really nice and not just "for a first batch". I'm really impressed with the shine you ended up with.
Post by Jugglerguy on May 26, 2022 19:10:09 GMT -5
Those look really good, Ashley! Congratulations!
Post by Deleted on May 26, 2022 19:35:46 GMT -5
Post by hummingbirdstones on May 26, 2022 19:55:15 GMT -5
Wow, great shine on those rocks for your first batch! Way to go!
Post by Deleted on May 26, 2022 21:08:43 GMT -5
Thank you hummingbirdstones ! hope my next batch isn’t a dud lol! I have a batch of chert running in 120/220 SC. It ran for 2 days and looked ok, but I put it back in again for a few more days. I’ll post that in a week or so when it’s done, it’s stuff we found locally (Illinois) and up in Wisconsin.
Post by rockjunquie on May 26, 2022 21:15:04 GMT -5
Y'all did a fine job! I'm impressed with the rough that came with it. It isn't usually as nice from what I have seen.
Post by Deleted on May 26, 2022 21:52:58 GMT -5
quartzilla
Member since April 2020
Post by quartzilla on May 29, 2022 22:18:01 GMT -5
Nice first batch! Your off to a rock in’ start!
markb
Member since May 2022
Post by markb on May 30, 2022 1:18:10 GMT -5
ashley I think they look GREAT! I love the tinies you include in the batch too. We have a canning jar that I put my tinies into and other small stuff. I bet your kids are loving it.
Post by Deleted on May 30, 2022 9:12:37 GMT -5
