Post by fernwood on Jun 4, 2022 7:09:47 GMT -5
For those who sometimes use epoxy for bails, etc. I had been using a toothpick dipped in acetone to remove any epoxy that ended up on the edges of bails. Usually do not worry if the bail is entirely on the back, but will remove any excess for bails that are somewhat on the front. Now that I am attaching cast/stamped items to rocks, I am wondering if this is the best method. I am using excess epoxy to be sure the item stays attached to the rock/cab. Am wondering if a small paint brush, made from material that acetone does not melt, would be better. Here is an example. The excess epoxy needs to be removed. The horse is brass, if that helps. I have never used acetone on brass embelishments, so do not know how it will react. Thanks.
Post by drocknut on Jun 4, 2022 8:28:32 GMT -5
Sorry, can't help with your question. When I use epoxy I usually try to remove it before it dries. Hope you find something that works great for you.
Post by manofglass on Jun 4, 2022 9:34:01 GMT -5
Post by liveoak on Jun 6, 2022 6:06:56 GMT -5
As far as I know acetone will not hurt brass. Also, sometimes, before the epoxy cures you can clean up with alcohol.
Patty
Post by fernwood on Jun 6, 2022 6:47:13 GMT -5
Thanks everyone. I appreciate the input, as this is new territory for me.
Post by rmf on Jun 6, 2022 13:04:54 GMT -5
liveoak is correct acetone does not affect brass. Acetone is way cheaper than attack at KN and is the active component. Use in well ventilated area. I use it regularly as a glue solvent. It is also the main component in fingernail polish remover.
Post by opalpyrexia on Jun 6, 2022 15:00:02 GMT -5
Based on my general and Repair Café experience (my family often refers to me as "Mr. Adhesives"), I recommend applying as little epoxy as necessary to ideally avoid having to remove any excess — duh.
For epoxy applications that require clean or invisible repairs, I use these fine brushes from Amazon: 100 Brushes for $10
