gailc
Member since June 2022
Post by gailc on Jun 8, 2022 18:15:42 GMT -5
I have a thumlers A R1 and like many others, have a issue with a hole wearing out in the center. I'm wondering if there is a different brand barrel that will fit the tumbler? Maybe one with a lid held on with a nut? I really like how the lids on my chicago electric work.
If not, any way to fix up a new lid so it lasts more than a couple months?
Mark K
Member since April 2012
Post by Mark K on Jun 8, 2022 23:03:50 GMT -5
I have glued a quarter over the hole in a pinch. Still have it somewhere.
gailc
Post by gailc on Jun 9, 2022 11:57:58 GMT -5
I have a chunk of rubber glued on for now but the lid will need replaced soon, would really like a fix to prevent such quick wear. Its such a bad design, a lid shouldn't fail in 2 months.
Post by manofglass on Jun 9, 2022 12:18:23 GMT -5
Drill the lid out with a holesaw then put a test plug in it or remove the cap and use a test plug if you can find one to fit I use the plastic test plugs with PVC barrels
gailc
Post by gailc on Jun 9, 2022 14:08:16 GMT -5
Drill the lid out with a holesaw then put a test plug in it or remove the cap and use a test plug if you can find one to fit I use the plastic test plugs with PVC barrels Thank you, those could work if I can find the right size
Post by stefan on Jun 11, 2022 18:56:05 GMT -5
I just crazy glue a thick (1/8") acrylic disk on the lid. I usually get several years of use this way. I have glued progressively smaller disks as they wear out, but replacement lids are not that expensive.
gailc
Post by gailc on Jun 25, 2022 19:36:47 GMT -5
I ended up buying a acrylic lid for it, advertised as being twice as strong as the original. We'll see how it holds up
Mark K
Post by Mark K on Jun 25, 2022 23:05:18 GMT -5
where did you find it?
