wfpii
Member since November 2018
Post by wfpii on Jun 24, 2022 12:23:27 GMT -5
When drilling a hole if you drill most of the way through, how do you know where to start drilling on the back side so you don't have a break through?
Bill
Post by stefan on Jun 24, 2022 13:18:56 GMT -5
I just deal with break through. you could take a set of painstaking measurements, but I used a little silicon mat to set the rock on and break through is minimal.
Post by vegasjames on Jun 24, 2022 17:34:34 GMT -5
Best to drill the stone before cabbing so the breakthrough can be ground off. Or it already cabbed maybe add a thick layer of glue to the backside, then drill the cab and remove the glue.
Post by Rockoonz on Jun 24, 2022 20:21:17 GMT -5
I use a ball end burr to drill focal beads, and while drilling I keep a finger over the exit point, when I feel a tickle I flip it and finish.
Post by jasoninsd on Jun 24, 2022 21:34:11 GMT -5
Out of curiosity...what if a person drilled the hole with a smaller bit...so any "break through" chipping would be minimal? Then the "correct" sized drill bit could be used afterward...
Post by stefan on Jun 26, 2022 8:36:09 GMT -5
Jason- you would still get break through with the larger bit. I even tried duct tape (which helped some).
Post by hummingbirdstones on Jun 26, 2022 8:42:09 GMT -5
Out of curiosity...what if a person drilled the hole with a smaller bit...so any "break through" chipping would be minimal? Then the "correct" sized drill bit could be used afterward... I think that would work if you already have the hole. Just drill half way from each end to the center and there should be little or no chipping.
rockbrain
Member since January 2022
Post by rockbrain on Jun 26, 2022 10:27:19 GMT -5
I've drilled several stones and for some reason I've not had any break through. I'm using cheap bits from Harbor Freight. I tried the trick that I read here. Put your finger behind the stone until you feel a tickle then turn it over and drill from the other side. The blood showed up the same time as the "tickle". We've not drilled a tremendous quantity, maybe a dozen, but we just haven't had any issues yet. Cheap Harbor Freight bits, cheap plastic vice in a pan of water, cheap flexible Dremel shaft.
Post by greig on Jun 26, 2022 17:22:35 GMT -5
I have only "drilled" a few but have been successful. I put the stone in a cup of water to keep the bit and stone cool and drill(really grind) slowly. If I had a drill press, I would use that for more control.
wfpii
Post by wfpii on Jun 28, 2022 14:00:45 GMT -5
Thank you for all suggestions!
Bill
