Post by Deleted on Aug 9, 2022 19:52:02 GMT -5
lucy
Becoming obsessed with rocks
Member since June 2022
Post by lucy on Aug 9, 2022 19:57:44 GMT -5
Pretty ashley! You should be proud!
Post by rockjunquie on Aug 9, 2022 19:58:02 GMT -5
Yay! So, what do you think? Think you'll do more like that?
rockbrain
Member since January 2022
Post by rockbrain on Aug 9, 2022 20:45:27 GMT -5
Time to get some wire...
Post by hummingbirdstones on Aug 9, 2022 20:51:22 GMT -5
Great job, ashley! They have an awesome polish on them.
Post by Deleted on Aug 9, 2022 21:15:01 GMT -5
Thanks lucy! the agate was really pretty but has some tiny cracks that allowed polish to get inside the rock which takes away from the shine.
Post by Deleted on Aug 9, 2022 21:17:47 GMT -5
rockjunquieThank you Tela! It was not super easy but it was fun. Now I’m working on the whole dome thing. Maybe I’ll do something for the August cab contest.
Post by rockjunquie on Aug 9, 2022 21:18:53 GMT -5
rockjunquie Maybe I’ll do something for the August cab contest. I hope you do!
Post by Deleted on Aug 9, 2022 21:20:15 GMT -5
rockbrainYes! I got some wire and started on a tumbled rock I have it was ummm, let’s say interesting lol! I wish someone on here had some video tutorials. I know I can look on YouTube but it would be fun to see from a friendly face.
Post by Deleted on Aug 9, 2022 21:20:55 GMT -5
Post by Deleted on Aug 9, 2022 21:23:58 GMT -5
rockjunquieThanks Tela! ☺️ I have one I’m working on now for it, hopefully I can get a nice dome on it.
Post by liveoak on Aug 10, 2022 6:45:25 GMT -5
Looks like a good starting point - look forward to see what you make with them.
Somehow I bet there's a cabber unit in your future.
Get watching the used stuff sales :-)
Patty
Post by Rockoonz on Aug 10, 2022 8:59:49 GMT -5
According to categories of competitive cab judging by AFMS rules, flat tops are also cabs, just another type. One way to deal with polish in cracks or "micropits" in the stone is to try an acidic solution and see if it will boil out. Even lemon juice or vinegar might work, an ultrasonic cleaner helps. Having trouble remembering what is the name for the acid we use for getting iron stains off of crystals, but it works really good for cerium, and probably other polishes.
Post by Deleted on Aug 10, 2022 9:30:43 GMT -5
liveoakThanks Patty! I think your right, when the money is there lol!
Post by Deleted on Aug 10, 2022 11:20:33 GMT -5
RockoonzThanks Lee, thats good to know! Thanks for the suggestions I will give that a go. It’s a really pretty piece but that grit that’s trapped takes away from it.
Post by Starguy on Aug 10, 2022 11:38:58 GMT -5
Hey ashleyThe domeless cabs turned out good. I watch for those cracks while cleaning out coarse stage barrels. When I see them, I’ll set them aside. Cracks get hammered, or chiseled to remove them. Sometimes, I will try to clamp the slab in a vice and try to break it on the crack. I don’t always get all of the crack to go away but it’s usually better after treating them. If they’re small cracks or pits, I’ll sometimes spend some time grinding on them with the CabKing. It’s worth the effort if you can turn a so-so tumbled rock into a premium tumbled rock. Nice job on those.
Post by Deleted on Aug 10, 2022 11:43:07 GMT -5
StarguyThank you Brent! thanks for the tips, will have to give that a try next time.
Post by jasoninsd on Aug 10, 2022 17:24:08 GMT -5
I like that you are giving this a shot Ashley! The more you work on the cabs with a Dremel, the better you're going to get at it. I really do believe you're going to be able to figure the dome out!
Post by Pat on Aug 10, 2022 19:10:55 GMT -5
According to categories of competitive cab judging by AFMS rules, flat tops are also cabs, just another type. One way to deal with polish in cracks or "micropits" in the stone is to try an acidic solution and see if it will boil out. Even lemon juice or vinegar might work, an ultrasonic cleaner helps. Having trouble remembering what is the name for the acid we use for getting iron stains off of crystals, but it works really good for cerium, and probably other polishes. You mean IRON OUT? Good stuff
Post by Deleted on Aug 10, 2022 19:42:09 GMT -5
jasoninsdThank you Jason! I sure hope so. I have better hopes for the dome then I do wire wrapping lol. I would show you guys my first attempt but I’m not done completely and it’s horrible!
