Post by Deleted on Aug 16, 2022 19:09:11 GMT -5
Post by Deleted on Aug 16, 2022 19:10:02 GMT -5
Post by Deleted on Aug 16, 2022 19:10:28 GMT -5
Post by Deleted on Aug 16, 2022 19:11:04 GMT -5
Post by Deleted on Aug 16, 2022 19:12:26 GMT -5
liveoakThank you Patty! I will keep that in mind.
Post by Deleted on Aug 16, 2022 19:13:25 GMT -5
Post by Deleted on Aug 16, 2022 19:13:56 GMT -5
Wow, it is beautiful, congrats! Thank you!
Post by Deleted on Aug 16, 2022 19:14:57 GMT -5
Post by liveoak on Aug 16, 2022 19:27:24 GMT -5
liveoak Thank you Patty! I will keep that in mind. I should have been more specific ashley, The pumice wheels will go in your Dremel, and with a small amount of effort will polish tool marks away,
BUT the good part is that the pumice won't hurt most stones, if you hit it with the wheel by mistake.
It's a good thing to have up your sleeve for wire wrapping , DAMHIKT
Patty
Post by rockjunquie on Aug 17, 2022 10:13:59 GMT -5
If the marks are not too bad, just use an emery board. I have one that has different grades of grit, so I can smooth it out real good and hit it with a polishing cloth. Propolish pads are good, too. But, for overall cleaning, degreasing, polishing, deburring and removing tool marks - I tumble. I used to do all my wraps, but now just when they need it.
Post by fernwood on Aug 18, 2022 3:58:39 GMT -5
Nice wrap. I have a fingernail "tool" that I use. There are 4 sides. The base is foam. Its intended use was to file and smooth ridges on fingernails. Then to buff them to a shine. Smooth, finish, prepolish and polish. It works great for touch ups on many things.
Post by Deleted on Aug 18, 2022 8:46:59 GMT -5
