Post by Deleted on Aug 22, 2022 14:07:06 GMT -5
rockbrain
Member since January 2022
Post by rockbrain on Aug 22, 2022 14:27:21 GMT -5
ashley I think you did an amazing job on that and you should be proud of it. It's got a dome and girdle a flat back and a great shine. Did you do this with a Dremel? Anyone can make a cab with a cab machine
My sad cab
Aug 22, 2022 14:48:17 GMT -5
via mobile
Post by Deleted on Aug 22, 2022 14:48:17 GMT -5
rockbrainThank you! I did use the dremel. Then threw it in the lot o. I think he’s pretty sad looking.
realrockhound
Chucking leaverite at tweekers
Member since June 2020
Member is Online
Post by realrockhound on Aug 22, 2022 15:32:39 GMT -5
I think it turned out good for what you’re working with and while dialing in technique.
My sad cab
Aug 22, 2022 16:00:11 GMT -5
via mobile
Post by Deleted on Aug 22, 2022 16:00:11 GMT -5
Post by Pat on Aug 22, 2022 16:06:09 GMT -5
Good job!! Enter it in the contest!
Post by opalpyrexia on Aug 22, 2022 16:13:05 GMT -5
... but as you can tell he didn’t turn out too great.
Not me. I see a curved cab that turned out really well. The combination of its curved top with the color patterns at its bottom has the potential for a very attractive pendant. Nice work.
Post by jasoninsd on Aug 22, 2022 18:45:09 GMT -5
Ashley...you're like "right there" on the edge of figuring it all out! I think it's a GREAT effort on this cab. I get what you're saying...it does have flaws...but I think it's a step in the right direction to figuring things out! Keep at it!!
Post by liveoak on Aug 22, 2022 19:18:54 GMT -5
Good start ashley, and a worthy pendant to be had. Easy for me to say, as I have a cabber & you're using a Dremel, but I'd suggest you start with a template shape instead of free form. At least that way if the tumbler rounds it out, you started it on the right track. Patty
Post by rmf on Aug 22, 2022 21:06:20 GMT -5
ashley The polish is good, the shaping needs a little work and the material has some imperfections but you need to set proper expectations. This is a good job for a newbie. I am assuming you started some time around Jan of this year. Anything done well takes time and experience. What I learned when I experimented with tumbling cabs years ago. I DON'T LIKE THEM as well as a hand finished cab. First to get a great tumbling job the material must be homogeneous. That means every bite of my Sub sandwich I want the meat, the cheese and all the veggies and the sauce (Mustard) in equal amounts in every bite. A good starter cab material would be like Brazilian Agate because it is a very homogeneous material. Any imperfections in the stone can be enhanced by the tumbler. The tumbler is dumb. If it "sees" a weak area like a vug it keeps grinding the "spot". Where when you are hand grinding you can avoid or remove at the right time or grit (hopefully). The end result of the soft spot is a dip in the polished surface that you may not have gotten if you hand ground the cab. If it happens on the edge then the edge is not straight or uniformly curved etc. Your chosen equipment will also affect the cab. For most cabs on here they have a 80-85 deg angled shoulder (off horizontal - the back) then the top is a low dome. With only the slightest rounding of the edge to prevent chipping. That is not what you should be doing if you are polishing cabs unless you are taking them down to 220 grit by hand then finishing from there. For tumbling you should start (IMHO) with a traditional cab where you have an curve that produces a completely shoulder like cabs use to be when everyone was grinding with SiC not diamond. see this for shape: That shape take advantage of the cab and the tumblers best features. Don't tumble in anything coarser that 220 grit due to too much grinding. Check frequently to see how material is progressing until you get under 600 grit. At the end of the day my first cab was travertine (which is soft) it had some flats and was not perfect. It did have a good polish. It mounted into a mount and I sold it. That's right it was good enough to sell. Yours are too. You let your customers pay for additional training, experience and fun. They don't need to know anything else about it other than it is pretty.
Post by fernwood on Aug 23, 2022 4:45:27 GMT -5
I think it turned out great. Nice job.
Post by rockjunquie on Aug 23, 2022 6:28:36 GMT -5
That's a dangerous curve you got on there! Very appropriate for the contest! Go for it!
Post by jasoninsd on Aug 23, 2022 8:26:20 GMT -5
ashley The polish is good, the shaping needs a little work and the material has some imperfections but you need to set proper expectations. This is a good job for a newbie. I am assuming you started some time around Jan of this year. Anything done well takes time and experience. What I learned when I experimented with tumbling cabs years ago. I DON'T LIKE THEM as well as a hand finished cab. First to get a great tumbling job the material must be homogeneous. That means every bite of my Sub sandwich I want the meat, the cheese and all the veggies and the sauce (Mustard) in equal amounts in every bite. A good starter cab material would be like Brazilian Agate because it is a very homogeneous material. Any imperfections in the stone can be enhanced by the tumbler. The tumbler is dumb. If it "sees" a weak area like a vug it keeps grinding the "spot". Where when you are hand grinding you can avoid or remove at the right time or grit (hopefully). The end result of the soft spot is a dip in the polished surface that you may not have gotten if you hand ground the cab. If it happens on the edge then the edge is not straight or uniformly curved etc. Your chosen equipment will also affect the cab. For most cabs on here they have a 80-85 deg angled shoulder (off horizontal - the back) then the top is a low dome. With only the slightest rounding of the edge to prevent chipping. That is not what you should be doing if you are polishing cabs unless you are taking them down to 220 grit by hand then finishing from there. For tumbling you should start (IMHO) with a traditional cab where you have an curve that produces a completely shoulder like cabs use to be when everyone was grinding with SiC not diamond. see this for shape: That shape take advantage of the cab and the tumblers best features. Don't tumble in anything coarser that 220 grit due to too much grinding. Check frequently to see how material is progressing until you get under 600 grit. At the end of the day my first cab was travertine (which is soft) it had some flats and was not perfect. It did have a good polish. It mounted into a mount and I sold it. That's right it was good enough to sell. Yours are too. You let your customers pay for additional training, experience and fun. They don't need to know anything else about it other than it is pretty. So VERY well explained rmf!! This is a fantastic post!!
Post by rockjunquie on Aug 23, 2022 11:13:06 GMT -5
ashley, Every time I see the title to this thread- My sad cab- it makes me sad that you should think about your work like that. I think your cab is a great effort and a good beginning. I can't think of it as sad, at all.
Post by Rockoonz on Aug 23, 2022 13:44:19 GMT -5
One day I will have to find my sad little first cab and post it. Truly sad thing is I had a pretty good set of tools to do it with and it turned out that way anyway. Keep it and put it alongside what you're making in a few months or so.
Post by mohs on Aug 23, 2022 16:06:06 GMT -5
caddywampus can be gniess that rocks ! Plus I have more than my fair share of sad rock hearts many have even seen them a few have even received them
Post by rockjunquie on Aug 23, 2022 16:56:22 GMT -5
caddywampus can be gniess that rocks ! Plus I have more than my fair share of sad rock hearts many have even seen them a few have even received them Your hearts are NOT sad- they are HAPPY hearts!
Post by mohs on Aug 23, 2022 18:48:41 GMT -5
Yes they are rockjunquie Tela! I was just pulling on heart strings Figure I earned a little of that Through all the hardt grinds I endowed them with the power of heartfullness Even if many are caddywampus They still rock & shine... Tanks
My sad cab
Aug 23, 2022 22:32:55 GMT -5
via mobile
Post by Deleted on Aug 23, 2022 22:32:55 GMT -5
PatYour too sweet Pat! This little guy has no place in a contest with the cabs on here. Maybe with time.
My sad cab
Aug 23, 2022 22:34:13 GMT -5
via mobile
Post by Deleted on Aug 23, 2022 22:34:13 GMT -5
