Mark K
Member since April 2012
Post by Mark K on Oct 28, 2013 20:28:30 GMT -5
It is still on the pallet in my truck. It weighs 320 pounds and I will have to have help getting it out.
It is too dark to take pics, but it looks good so far. Also looks like all I will have to do is put the belt on and fill it with oil to get it going.
RockIt2Me
Member since December 2009
Post by RockIt2Me on Oct 28, 2013 20:33:41 GMT -5
Yay!
Post by Rockoonz on Oct 28, 2013 20:36:19 GMT -5
OK pics tomorrow AT DAWN will be acceptable Lee
Post by jamesp on Oct 28, 2013 20:38:53 GMT -5
Congratulation. pics man pics
Post by orrum on Oct 29, 2013 8:35:24 GMT -5
How much does a 20 inch blade cost and how long does it last? How much oil to fill it and how long does the oil last and how often do you need to top the oil off? I want a big saw bad! LOL Congratulations on getting a very nice big saw!!!!
Post by Fossilman on Oct 29, 2013 10:44:37 GMT -5
AWESOME!
Post by Deleted on Oct 29, 2013 13:31:40 GMT -5
What, you do not have a flash? You should know that with photos on here instantly is not fast enough. lol Jim
Post by pghram on Oct 29, 2013 14:06:49 GMT -5
Congrats!
Rich
kaldorlon
Member since October 2013
Post by kaldorlon on Oct 29, 2013 14:09:20 GMT -5
Congrats and can't wait to see pics!
bsky4463
Member since September 2013
Post by bsky4463 on Oct 29, 2013 14:46:49 GMT -5
Right on! Looking forward to seeing your new rig. Just hope it never breaks down....I am waiting on a part for mine and I am going thru major withdrawal.
Mark K
Post by Mark K on Oct 29, 2013 16:20:57 GMT -5
Post by Peruano on Oct 29, 2013 16:25:08 GMT -5
It looks ready to run. I'm guessing you will want a larger shield on the blade. In the motorcycle world your blade shield would be constitute a bobber. It will definitely throw oil toward the back of the hood. Happy cutting. Tom
Mark K
Post by Mark K on Oct 29, 2013 18:14:05 GMT -5
It runs, it cuts great, but it keeps blowing the circuit. I will have to let things cool down. Then I will have to make sure no one is running anything on that circuit.
Post by Deleted on Oct 29, 2013 18:21:26 GMT -5
Might have a short in the cord or connections.
Ask me how I know!
Mine did!
Post by Deleted on Oct 29, 2013 18:32:26 GMT -5
I thought you were getting a fancy new one but you did way better than that with a nice broken in one. Way to go. Jim
Post by johnjsgems on Oct 29, 2013 19:35:33 GMT -5
My HP 24 ran OK on 120 volts on a 20 amp circuit. I think it had a 1 1/2 hp motor. If you have an amp meter (Harbor Freight has them for $10-$15) you can see if you are over amping. If saw was stored a long time (or not) blow out any air vent holes on the motor and look for any signs of oil ports. Oil if there are oilers. You can also remove the motor belt and spin the motor shaft by hand. Feel for drag, roughness, or side to side play.
Post by roy on Oct 29, 2013 20:54:08 GMT -5
looks great if the blade is dull it could cause that problem cut something small or something soft and see if that happins if so the motor could be worn out!also check were the motor is wired some motors can be wired 110 or 220 its possiable that it was wired wrong that has happined to me once
Mark K
Post by Mark K on Oct 29, 2013 22:14:58 GMT -5
I figured it out. The freezer is on the same circuit. When it kicked in, the breaker would go. Anyway, I had to play with it. You know I did. I cut a chunk of MT Diamond country rock, but it was unremarkable, so I pitched it. Here is a slice of Brenda jasper(or is it agate)that I cut. I found the rock on my last trip.
Post by phil on Oct 31, 2013 12:20:32 GMT -5
Motor could just be getting old and drawing too much current. Is it one that will allow brush replacement? Check your rating on the motor, you circuit should be able to handle it easily. My 20 inch uses only 8 or 9 amps.
Mark K
Post by Mark K on Oct 31, 2013 15:12:36 GMT -5
Well, I though I had it figured out. I am 3/4 of the way through a 7 inch chunk of mushroom and it keeps kicking the breaker. It will rum forever if the feed is not engaged, but once it hits rock, it balks and blows. This house is set up with 15 amp circuits. I don't like it one bit. It is also set up weird as one room will half blow and so will another.
I have an idea for an experiment.
