Post by rockjunquie on Jan 9, 2014 10:33:13 GMT -5
I have been using a common set of needle files from Craftsman. I don't even know the cut. I see reference to different cuts ie 2,3,4. What is the best kind to get?
Post by rockjunquie on Jan 9, 2014 10:43:22 GMT -5
Post by 1dave on Jan 9, 2014 14:39:25 GMT -5
I got a hand full from a pawn shop for $5.
Very course for serrated bezels, very fine for smoothing with the least scratches, make knife blades out of them when all else fails.
Post by rockjunquie on Jan 9, 2014 16:47:27 GMT -5
How are they numbered though? My set doesn't have a number, but it is pretty coarse. I'm thinking that 2 would be more coarse than 4? Anyone know for sure?
Post by Pat on Jan 9, 2014 17:03:08 GMT -5
Tela, I'd like to know, too. I just feel them.
Generally, from coarsest to finest: big metal files, needle files, popsicle sticks (sandpaper), cloth, compounds on wheel, propad (rio).
I hope someone can attach numbers to the above, or correct me, though most of my files to do not have numbers.
Post by Pat on Jan 9, 2014 17:07:29 GMT -5
I just found this on rio: www.riogrande.com/Content/Defining-Files-HT-psd?Pos=0I figure the more teeth, the finer. Steps Step 1: The cut of the file refers to how fine its teeth are. They are defined from roughest to smoothest. A single-cut file has one set of parallel teeth while a cross-cut or double-cut file has a second set of teeth. Step 2: • FILE CUTS Files are graded by numbers ranging from 00 (the coarsest) to 6 (the finest). CUT # TEETH/INCH 00 38 0 51 1 64 2 79 3 97 4 117 6 173
Post by 1dave on Jan 9, 2014 17:41:19 GMT -5
Post by rockjunquie on Jan 10, 2014 11:54:34 GMT -5
Thanks you two. I should have found those myself. I guess I was deferring to experience. I need a good set and don't know which to get.
Post by Pat on Jan 10, 2014 12:01:43 GMT -5
My most used files are the flat and the half-round hand files, and the set of needle files. I'll have to check which number they are. Frequently there is not a number.
Post by rockjunquie on Jan 10, 2014 13:16:07 GMT -5
My most used files are the flat and the half-round hand files, and the set of needle files. I'll have to check which number they are. Frequently there is not a number. Thank you, Pat. The cheap set I have has no number. They seem pretty coarse to me, but I don't have much to compare the to. I have a wide general purpose hardware store file. It's flat. I have learned over the years that it is best to have the right tools to start with. It's very hard to learn a new skill when you don't have what you need to achieve a success. I'm all for improvising and I do... a lot. But, that will come after I have the basics down.
Tom
Post by Tom on Jan 10, 2014 13:16:16 GMT -5
I am not sure that your set of craftsman files might not be all you need, what with sanding sticks and whatnot:) Although I am a bad one to say that cause I like to have tools LOL
Post by rockjunquie on Jan 10, 2014 13:16:55 GMT -5
I am not sure that your set of craftsman files might not be all you need, what with sanding sticks and whatnot:) Although I am a bad one to say that cause I like to have tools LOL LOL! We posted at the same time.
Post by Rockoonz on Jan 10, 2014 15:10:10 GMT -5
Post by 1dave on Jan 10, 2014 15:48:22 GMT -5
IMO you can't have enough files. Even in silversmithing these "Riffle Files" come in handy. They are usually used in "checkering" rifle stocks.
Post by Pat on Jan 10, 2014 16:48:39 GMT -5
Post by Rockoonz on Jan 10, 2014 16:53:07 GMT -5
IMO you can't have enough files. Even in silversmithing these "Riffle Files" come in handy. They are usually used in "checkering" rifle stocks. I have some for carving soapstone and alabaster
Post by Pat on Jan 10, 2014 17:06:58 GMT -5
IMO you can't have enough files. Even in silversmithing these "Riffle Files" come in handy. They are usually used in "checkering" rifle stocks. I have some for carving soapstone and alabaster I agree. For many people, part of the fun of metalsmithing is all the different toys/tools. Friends are always finding something new, or a new way of using an item. It's fun.
Post by Rockoonz on Jan 10, 2014 17:19:27 GMT -5
Seems that often I spend more time with tools than I do with rock.
Lee#2
Tom
Post by Tom on Jan 10, 2014 18:30:06 GMT -5
Nice guide, I now know more about files, alot more
Post by talkingstones on Jan 10, 2014 19:09:09 GMT -5
Hi guys. I tried filing on the bead with a set of needle files I inherited from my dad. Ended up using his dremmel and diamond bit after breaking the center joint for the bazilianth time. I found that I didn't have to use the kind of pressure I did with files and didn't have the residual problems incurred with the motion damage from moving the files back and for the with the dremmel.
Is there a reason not to do this?
Cathy
