Post by radio on May 12, 2016 19:37:48 GMT -5
Took in this ring for repair yesterday and recalled a thread not long ago about setting stones with glue. This is the perfect example of why it shouldn't be done in a quality piece. 18 Karat gold ring with a good size diamond, but who ever did the piece took some shortcuts in setting the Onyx. This ring is about 8 years old and the glue has already deteriorated badly allowing the thin Onyx stone to crack and pieces of it fall out. I will use a diamond burr to deepen the recess a bit and level the base before cutting and setting a new stone. I will also drill 4 tiny holes through the gold so the liquid steel I use will form pillars and not allow the stone to shift and crack like it did before
Post by rockjunquie on May 12, 2016 19:46:37 GMT -5
Only 8 years old??? Wow, just wow. Looks like a big repair job.
Post by radio on May 12, 2016 20:09:08 GMT -5
Only 8 years old??? Wow, just wow. Looks like a big repair job. As you can see from the scratches in the gold, he is not a desk job type guy This was a soft, gooey glue and most likely E6000. Most definitely not a two part epoxy. Yes, it is a big repair job and was priced accordingly Gonna be a real bear to cut and fit new Onyx, especially that thin. I most likely will leave the stone a bit thicker than needed, set it with liquid steel, allow it to cure then very carefully work the stone level with the gold
Post by rockjunquie on May 12, 2016 20:11:06 GMT -5
Maybe, he should leave his ring at home. Would be cheaper.
Post by Deleted on May 12, 2016 20:19:32 GMT -5
What stone will be "black onyx"?
He found the right artist to do his repair.
Post by radio on May 12, 2016 20:36:35 GMT -5
What stone will be "black onyx"? He found the right artist to do his repair. well, just plain 'ol "Onyx" then Funny how very few people these days will tackle repairs unless they can order a calibrated replacement stone off the internet
Post by Deleted on May 12, 2016 20:38:05 GMT -5
What stone will be "black onyx"? He found the right artist to do his repair. well, just plain 'ol "Onyx" then Forgive my niavete, what exactly is "onyx"? Im being sincere. I have no clue.
panamark
Member since September 2012
Post by panamark on May 12, 2016 20:41:11 GMT -5
Like others have noted, that guy is pretty hard on rings.
Post by radio on May 12, 2016 20:42:13 GMT -5
well, just plain 'ol "Onyx" then Forgive my niavete, what exactly is "onyx"? Im being sincere. I have no clue. Sorry, thought you were giving me a tough time as most Onxy is black, but there are banded varieties. Wickipedia description>>> en.wikipedia.org/wiki/Onyx
Post by radio on May 12, 2016 20:43:58 GMT -5
Like others have noted, that guy is pretty hard on rings. He is, but keep in mind the picture is much more than actual size, so shows every tiny scratch as though it was a deep gouge
Post by Deleted on May 12, 2016 20:44:32 GMT -5
Forgive my niavete, what exactly is "onyx"? Im being sincere. I have no clue. Sorry, thought you were giving me a tough time as most Onxy is black, but there are banded varieties. Wickipedia description>>> en.wikipedia.org/wiki/OnyxI stipulate onyx is black agate. Where does black onyx come from? I know a hard rock place to get some, but not commercial qty...
Post by Rockoonz on May 12, 2016 20:54:27 GMT -5
True Onyx is striped agate, most black onyx is dyed. Sardonyx is red striped instead of black. Some refer to Travertine as onyx, but it is not. en.wikipedia.org/wiki/Onyx
wampidytoo
Add 5016 to my post count.
Member since June 2013
Post by wampidytoo on May 12, 2016 23:18:43 GMT -5
Have you thought about replacing it with black jade? Way less chance of it breaking or chipping. Jim
Post by radio on May 13, 2016 7:45:45 GMT -5
Have you thought about replacing it with black jade? Way less chance of it breaking or chipping. Jim I thought of a few different alternatives, but never thought of Jade. any suggestions where to pick up just a small slab, or even a cab I can re work? I have some killer Psilomelane, but the patterns in it are quite pronounced, so I ruled it out
panamark
Post by panamark on May 13, 2016 9:36:56 GMT -5
Have you thought about replacing it with black jade? Way less chance of it breaking or chipping. Jim I thought of a few different alternatives, but never thought of Jade. any suggestions where to pick up just a small slab, or even a cab I can re work? I have some killer Psilomelane, but the patterns in it are quite pronounced, so I ruled it out I would be happy to send you a piece of black jade big enough for that. What dimensions do you need? (note that when this jade gets cut thin enough - say 1 mm thick, it turns green. But I am sure you will be thicker than that so it will look black.
Post by Rockoonz on May 13, 2016 11:08:33 GMT -5
Here is some onyx. Nowadays it is called onyx and that's fine with me as long as I understand it is limestone onyx (travertine) as opposed to striped agate.
Post by Deleted on May 13, 2016 13:11:17 GMT -5
Here is some onyx. Nowadays it is called onyx and that's fine with me as long as I understand it is limestone onyx (travertine) as opposed to striped agate. Hence my confusion.... Black jade, good call..... Itwill never break again.
metalsmith
Post by metalsmith on May 13, 2016 13:12:48 GMT -5
I pick up black onyx, naturally occuring, at the coast on the Cote d'Argent, near Bordeaux, France; generally only small tho.
Post by radio on May 13, 2016 14:44:15 GMT -5
I thought of a few different alternatives, but never thought of Jade. any suggestions where to pick up just a small slab, or even a cab I can re work? I have some killer Psilomelane, but the patterns in it are quite pronounced, so I ruled it out I would be happy to send you a piece of black jade big enough for that. What dimensions do you need? (note that when this jade gets cut thin enough - say 1 mm thick, it turns green. But I am sure you will be thicker than that so it will look black. Thanks! I have not measured for the stone yet, but likely about 15mm at the long point and perhaps 12mm wide. The recess it was set in is currently very shallow, but I plant to use a burr and deepen it slightly. I'm guessing it will be 2 mm thick or perhaps a shade over that. This is likely not the last piece I will take in to repair, so would gladly buy a slab from you as long as it is dark enough to be suitable for a Black Onyx replacement message me with details thanks
wampidytoo
Post by wampidytoo on May 13, 2016 19:05:34 GMT -5
Have you thought about replacing it with black jade? Way less chance of it breaking or chipping. Jim I thought of a few different alternatives, but never thought of Jade. any suggestions where to pick up just a small slab, or even a cab I can re work? I have some killer Psilomelane, but the patterns in it are quite pronounced, so I ruled it out I might be able to fix you up. Send your address. I charge postage. Jim
