Ocean Jasper, first finished tumbles, part 1
Sept 12, 2017 7:16:06 GMT -5
Fossilman, amygdule, and 5 more like this
Post by melf77 on Sept 12, 2017 7:16:06 GMT -5
If memory services me correct, gotta check my invoice
4 or 6 lbs of the Ocean Jasper rough from RockTumbler, didn't weigh the end result yet
~6 weeks total in 60/90 grit TT model B rotary, ran the Ocean Jasper with 4lbs of various red/yellow Jasper, Sunset Jasper, Picture Jasper. After a week, I did start to add the larger ceramic cylinders to fill from the loss of material. 1 to 1 1/2 week was without a slurry. All other steps had a slurry. first 2 weeks, I cleaned everything, each week and started with fresh grit. After the 2 weeks time, I left the 60/90 grit to run for a 2 full weeks before touching again after I was happy with the slurry.
~7 days 150/220 in the Thumblers MB vibe, just the Ocean Jasper, minus about 4-5 pieces that I held back to throw in the second Jasper load. Used about 1.5lbs of ceramic L cylinders. I know I didn't need to leave them in that long, but I am happy with how they turned out and I have more than enough time on my hands. I recharged w/ grit 2x's
~5 days 500 grit in the MB vibe, a bit more ceramic cylinders, didn't weigh, just eyeballed it until I had smooth movement. Recharged 1x
~4 Days of polish in the MB vibe again, replaced the L ceramics with plastic pellets and the 2mm ball ceramics to see how they were. Bought the beads/pellets to use with more fragile stuff down the road. Not a fan of either of them. Pain in the butt to clean, recharged 1x
~about 45 minutes of Ivory soap burnishing. Used the plastic pellets and ceramic beads here as well. I have very hard water where I live.
I started my second load of the remaining Jasper's I had to hold back on Sunday, due to buying the mini bowl vibe. Slurry to me, is easier to do in the vibe. I love how I can just remove the top any time to check on it, hence why I hate the plastic pellets as they start piling out of the vibe, the second you remove the top.
PICT0097 by disneynut1977, on Flickr
PICT0098 by disneynut1977, on FlickrPICT0101 by disneynut1977, on FlickrPICT0102 by disneynut1977, on FlickrPICT0107 by disneynut1977, on FlickrPICT0110 by disneynut1977, on FlickrPICT0129 by disneynut1977, on FlickrPICT0115 by disneynut1977, on FlickrPICT0120 by disneynut1977, on FlickrPICT0121 by disneynut1977, on FlickrPICT0124 by disneynut1977, on FlickrPICT0139 by disneynut1977, on FlickrPICT0113 by disneynut1977, on Flickr
