Post by Garage Rocker on Feb 23, 2018 22:13:10 GMT -5
Looking back, I see that I haven't posted any tumbles since November. I did shut down for a while during the sub-zero temps we experienced this winter. I have, though, finished three batches since that time and figured I would grab the camera and show what I've been up to. Here's a pretty good sampling:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
Sorry for the over abundance of photos. Will try not to get so many in future threads. For any newer members that may have comments or questions, please use the 'reply' prompt and not the 'quote' prompt, which will re-post all these photos again. I feel guilty enough, as is.
Randy
Post by Drummond Island Rocks on Feb 23, 2018 22:35:48 GMT -5
1 thru 34 are great but 21 and 26 are favorites. What are the ones in picture 21?
Post by MsAli on Feb 23, 2018 22:42:31 GMT -5
Wow! Several had me drooling but 23 is 😍😍😍😍
Post by Garage Rocker on Feb 23, 2018 22:46:20 GMT -5
1 thru 34 are great but 21 and 26 are favorites. What are the ones in picture 21? Chuck Thanks, Chuck. #21 is leftover pieces of yellow and black Kentucky agate, like this. The larger pieces have already been tumbled.
Post by aDave on Feb 23, 2018 23:35:28 GMT -5
Nice stuff as usual Randy Garage Rocker. Great variety and the photos are A-1. Do I see some Lavic in there? Hmmm, now where's that Kentucky agate that "someone" sent me? Good job. Dave
Post by quartz on Feb 23, 2018 23:36:56 GMT -5
Thanks for the fine show. I'd have to go with 33, very nice color and most unusual pattern.
pizzano
Member since February 2018
Post by pizzano on Feb 23, 2018 23:50:38 GMT -5
Very nice.....
On the Blue Lace Agate....#2, I assume they were tumbled....rotary or vibe or both....?
How did you reduce the undercutting of the softer "white" material....?.....I noticed some of yours still showed signs of it, but a whole lot less then mine turned out.
What material did you mix with that Agate....I tried other Agates, didn't go well for the Lace.
Thanks for the pic's.
fishnpinball
So much to learn, so little time
Member since March 2017
Post by fishnpinball on Feb 24, 2018 0:24:14 GMT -5
Lots of wow factor there.
NRG
Post by NRG on Feb 24, 2018 0:49:44 GMT -5
Badass
Does 26 have a vug or is the center full of exceptionally clear agate? Could be either from the pic and I saw the latter at class last week.
Post by Garage Rocker on Feb 24, 2018 1:51:44 GMT -5
Thanks for the fine show. I'd have to go with 33, very nice color and most unusual pattern. Thanks! That's a nice little Laker.
Post by Garage Rocker on Feb 24, 2018 1:53:47 GMT -5
Badass Does 26 have a vug or is the center full of exceptionally clear agate? Could be either from the pic and I saw the latter at class last week. Thanks, newbie! That's a vug. Just took a little attention at clean outs. It's one of my favorites from this bunch.
Post by Garage Rocker on Feb 24, 2018 2:09:25 GMT -5
Very nice..... On the Blue Lace Agate....#2, I assume they were tumbled....rotary or vibe or both....? How did you reduce the undercutting of the softer "white" material....?.....I noticed some of yours still showed signs of it, but a whole lot less then mine turned out. What material did you mix with that Agate....I tried other Agates, didn't go well for the Lace. Thanks for the pic's. Thank you! The blue lace was one of the more finicky tumbles I've tried lately. It tends to develop cracks, or hairline vugs, as it grinds. It took some brushing out to keep grit from moving on from step to step. I rotary tumbled the first stage and then moved on to the Lot O for finishing. It was tumbled with all the other material in these pics. I don't believe it would have done any better if tumbled on it's own. Just the nature of the material. There were some rejects that didn't make it, and others that just tumbled away to tiny pieces. The ones that made it are not all perfect, but still nice looking tumbles. Good luck with yours.
Post by Garage Rocker on Feb 24, 2018 2:16:16 GMT -5
Nice stuff as usual Randy Garage Rocker. Great variety and the photos are A-1. Do I see some Lavic in there? Hmmm, now where's that Kentucky agate that "someone" sent me? Good job. Dave Thanks Dave! If you see Lavic, it would be in #12. Not sure what those are. I had others that aren't pictured. There were too many tumbles to photo them all. Now, go find that KY agate and give it a go!
Post by aDave on Feb 24, 2018 3:05:23 GMT -5
Nice stuff as usual Randy Garage Rocker . Great variety and the photos are A-1. Do I see some Lavic in there? Hmmm, now where's that Kentucky agate that "someone" sent me? Good job. Dave Thanks Dave! If you see Lavic, it would be in #12. Not sure what those are. I had others that aren't pictured. There were too many tumbles to photo them all. Now, go find that KY agate and give it a go! 12 is the one I was thinking of, but when much of this stuff gets tumbled, it's hard to say for sure. I'll have to get that KY agate and cut it up. If I recall correctly, the piece was pretty large, so I'll have to roll it on the saw. Unless, of course, I can get back to Scott's class and use some of their larger saws. I wan't to avoid hitting it with a hammer. ETA: What is 23? I just pulled a finished batch today, and I have a rock (probably came from you) that looks almost identical. Makes me wonder if you cut it, and I got a piece of it.
Post by fernwood on Feb 24, 2018 4:23:01 GMT -5
Thanks for posting. Wonderful as usual.
Post by rockpickerforever on Feb 24, 2018 4:56:26 GMT -5
Great tumbles and variety from the master Cleft lip, no teeth
Post by jamesp on Feb 24, 2018 5:58:28 GMT -5
Post by rockjunquie on Feb 24, 2018 7:29:36 GMT -5
MMMMMMM sublime. Those are so shiny and purty. What is #4? Never seen that before.
Post by beefjello on Feb 24, 2018 9:32:40 GMT -5
Amazing work on both the stones and the photography!
Time to mop the drool off my keyboard
Yowza!!!
Post by Garage Rocker on Feb 24, 2018 9:44:48 GMT -5
"What is 23? I just pulled a finished batch today, and I have a rock (probably came from you) that looks almost identical. Makes me wonder if you cut it, and I got a piece of it." aDave, that is likely a Laguna agate. I usually cut them in half, to see the banding in the middle. I do tend to tumble half and give the other half away. You may very well have the twin. Look forward to seeing it.
