kittykatkane
Member since November 2021
Post by kittykatkane on Nov 16, 2021 7:02:03 GMT -5
I got this new tumbler it's a vibrating one but it won't stay sealed the lid keeps popping off. Does anyone have any advise on how to tighten it enough that it does not pop open or leak. Please help.
Post by Son Of Beach on Nov 16, 2021 7:11:31 GMT -5
Hey kittykatkane, I have a LOT-O Tumbler that has the same issue. I have a bungee cord that I tie around the base of the block it sits on and wraps around to the top of the lid. I've seen others use multiple of those longer rubberbands tied together to reach all the way round. What tumbler do you have?
Post by fernwood on Nov 16, 2021 8:42:45 GMT -5
I am prepared for my Lot O, when it is brought inside soon. Have the stock lid for it and some bungie cords. I also have many zip ties, so am thinking about just using those if the bungie cords do not work.
jimmie
Member since August 2021
Post by jimmie on Nov 16, 2021 9:10:48 GMT -5
I use rubber bands. Hook it on the knob on the bottom, over the top and fasten on the knob again. No more “pop offs”
kittykatkane
Post by kittykatkane on Nov 16, 2021 11:59:12 GMT -5
The tumbler I have is called pro-pount vibratory tumbler I wish I could add a picture here haha
Post by hummingbirdstones on Nov 16, 2021 21:50:17 GMT -5
The tumbler I have is called pro-pount vibratory tumbler I wish I could add a picture here haha Here's a link to the Cloudinary Tutorial for uploading pictures. Takes a little while to get through the process, but if you follow each step exactly you'll be uploading photos in no time. It only takes seconds once you have Cloudinary configured.
If you use a phone, the Tapatalk app is what folks use to upload from their phone.
CLErocks
Member since October 2021
Post by CLErocks on Nov 18, 2021 10:13:24 GMT -5
Are you sure that one is meant for wet tumbling? How much water are you putting in it??
CLErocks
Post by CLErocks on Nov 18, 2021 10:20:59 GMT -5
I’m thinking shouldn’t have water…
brybry
Enter your message here...
Post by brybry on Nov 18, 2021 12:17:59 GMT -5
Yeah, there's your problem.
Could potentially redneck engineer something with silicone/rubber washers but no guarantee it would work.
agatemaggot
Member since August 2006
Post by agatemaggot on Nov 18, 2021 12:44:02 GMT -5
Get an 8 by 10 piece of foam sheet at the Dollar store and trace around the lid to make a water proof gasket. A star lock nut under the thumb screw on top will keep the wing nut secure !
brybry
Post by brybry on Nov 18, 2021 18:14:53 GMT -5
#1 is begging for someone to redneck re-engineer it to make it work.
LazerFlash
The more they over-think the plumbing, the easier it is to stop up the toilet.
Member since September 2021
Post by LazerFlash on Nov 18, 2021 20:18:38 GMT -5
Eh, as much as I love a good Redneck Engineering project, my vote is for kittykatkane to return it and get one for wet tumbling.
