vwfence
Post by vwfence on Oct 31, 2022 11:12:29 GMT -5
Has anyone glued up slabs to make spheres and if yes , may i ask what glue you used ? Thanks in advance Wayne
callmerob
I really like a dirt road
Member since September 2019
Post by callmerob on Oct 31, 2022 13:13:47 GMT -5
Before I had any rocks suitable for spheres, I found 3/8+" thick marble floor tiles at Home Depot. The top polished surface is scratched with sand paper to give the glue some grip, using ordinary super glue. Don't skip this step. Ask me how I know. The rest of the process looks like this... Cut to 3" squares Layout and saw octagons Octagons Octagons Simple glueing fixture Not shown is wax paper between tiles and fixture. There is a surprising amount of glue squeeze-out which will glue the tiles to the fixture. Don't skip this step either. These are destined to be little planets with polar ice caps. Simple octahedral fixture. Octahedral fixture A bigger saw cuts the right-most vertical surface. Bigger because the cut is too high for the blade on a 6" trim saw. Note the wood shim (under the south pole) to allow the rock to protrude far enough so the blade clears the v-blocks. Ideally the flats are coincident with points on the sphere's surface. Inked with a Sharpie pen to show the low flat spots. When the ink is gone, it's round. Glad I started with marble tiles because it is a lot softer and easier to machine than quartz or jasper. Takes a nice polish too. Hope that helps.
AzRockGeek
Member since September 2016
Post by AzRockGeek on Oct 31, 2022 13:34:52 GMT -5
callmerob
Post by callmerob on Oct 31, 2022 14:39:34 GMT -5
I did many years ago, I used 330 epoxy, worked well. Outstanding! Very creative! Great looking sphere! I really like the checkerboard pattern. Reminds me of my Dad's hardwood kitchen cutting boards, laminated, resawn, every other one flipped over. Looks 3-dimensional with the optical illusion of depth. Think I see that in your beautiful sphere. Also I see a fabric quilt. My first attempt with Epoxy330 gave a noticeable glue line, so I tried super glue.
vwfence
Post by vwfence on Oct 31, 2022 22:53:10 GMT -5
is your machine made useing 8020
callmerob
Post by callmerob on Nov 1, 2022 10:14:17 GMT -5
