dreamrocks
Member since November 2018
Post by dreamrocks on Jul 8, 2024 19:42:13 GMT -5
Post by hummingbirdstones on Jul 8, 2024 19:47:15 GMT -5
Is that cacoxenite in amethyst? Turned out nice.
dreamrocks
Post by dreamrocks on Jul 8, 2024 19:52:15 GMT -5
No way I thought it was a fluorite! It’s the first time I have seen it. I like it! Thank you Have you seen tribeunited jelly sandwich is hers the same stuff?
dreamrocks
Post by dreamrocks on Jul 8, 2024 20:00:02 GMT -5
Is that cacoxenite in amethyst? Turned out nice. hummingbirdstones I have no idea I can’t find that in any of my mineral books. Is it a uncommon mineral?
Post by hummingbirdstones on Jul 8, 2024 20:08:10 GMT -5
Is that cacoxenite in amethyst? Turned out nice. hummingbirdstones I have no idea I can’t find that in any of my mineral books. Is it a uncommon mineral? Wouldn't say it's exactly uncommon, but it's become harder to find now.
dreamrocks
Post by dreamrocks on Jul 8, 2024 20:14:31 GMT -5
I bought it several years back from the new owner of a rock shop where the original owner past away. The new owner changed inventory and gave our rock club the opportunity to buy old stock of the original owner at a very good price on anything from the old stock at .35 a pound.
Couldn’t pass that up that deal thats how I came across it. Always thought it was fluorite,
dreamrocks
Post by dreamrocks on Jul 8, 2024 20:23:03 GMT -5
hummingbirdstones I have no idea I can’t find that in any of my mineral books. Is it a uncommon mineral? Wouldn't say it's exactly uncommon, but it's become harder to find now. hummingbirdstones thank you for the id I just found some online and that is what you said it is! For give me my spelling stinks. Some of the cabs I saw were killer with those gold needle inclusions mine has them to.
dreamrocks
Post by dreamrocks on Jul 8, 2024 20:30:23 GMT -5
Is that cacoxenite in amethyst? Turned out nice. hummingbirdstones I have no idea I can’t find that in any of my mineral books. Is it a uncommon mineral? The picture just isn’t picking up the needles that good but the whole bottom is pretty loaded with them. It wasn’t even so I only cleaned up the even end ![](https://uploads.tapatalk-cdn.com/20240709/f8ed4fe713ce73f6b86b58ef55139a2d.jpg)
tribeunited
Member since May 2024
Post by tribeunited on Jul 9, 2024 15:57:24 GMT -5
dreamrocks is that the same stuff as super7? I might be remembering it wrong. It might be called super5 or super8 i can't remember now. I thought I saw a post about it at one point somewhere. That's a super pretty piece regardless ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Delicious blueberry pie! YUM!
dreamrocks
Post by dreamrocks on Jul 9, 2024 16:04:09 GMT -5
Yes it does look pretty tasty. It’s called Cacoxenite in Amethyst it takes a real nice polish on the cabking only. I didn’t use any polish just the cabking for the final finish.
People tell me you can’t put a polish on a stone without using polish I can and I can’t see any difference using polish verses just working out a polish with the cabking.
Post by hummingbirdstones on Jul 9, 2024 18:27:34 GMT -5
dreamrocks is that the same stuff as super7? I might be remembering it wrong. It might be called super5 or super8 i can't remember now. I thought I saw a post about it at one point somewhere. That's a super pretty piece regardless ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Delicious blueberry pie! YUM! Not quite the same, but similar. Super 7 has 7 minerals in it, which I can't remember off the top of my dome.
Post by hummingbirdstones on Jul 9, 2024 18:31:16 GMT -5
Yes it does look pretty tasty. It’s called Cacoxenite in Amethyst it takes a real nice polish on the cabking only. I didn’t use any polish just the cabking for the final finish. People tell me you can’t put a polish on a stone without using polish I can and I can’t see any difference using polish verses just working out a polish with the cabking. You most definitely can get a fine polish just by using diamond wheels. You do not have to use a "polish" like cerium oxide. On some stones a polish may help get the perfect polish, but it's not mandatory. Obviously, the finer the diamond grit and you go up the grits, the better the polish.
dreamrocks
Post by dreamrocks on Jul 9, 2024 18:34:32 GMT -5
Thank you hummingbirdstonesGonna show my buddy this quote. Maybe he will believe me now!
dreamrocks
Post by dreamrocks on Jul 9, 2024 18:35:14 GMT -5
Oh I only went up to a 3,000 grit wheel
Post by hummingbirdstones on Jul 9, 2024 18:42:29 GMT -5
Oh I only went up to a 3,000 grit wheel If you go up to 14,000, it will really pop. Do you have a spin-on lap on the end of your machine? A 14,000 diamond pad or either a cerium oxide or tin oxide pad on the end would finish it off nicely. I believe cerium is what jasoninsd uses on his. Jason, correct me if I'm blowing smoke.
dreamrocks
Post by dreamrocks on Jul 9, 2024 18:48:10 GMT -5
Oh I only went up to a 3,000 grit wheel If you go up to 14,000, it will really pop. Do you have a spin-on lap on the end of your machine? A 14,000 diamond pad or either a cerium oxide or tin oxide pad on the end would finish it off nicely. I believe cerium is what jasoninsd uses on his. Jason, correct me if I'm blowing smoke. Yes I have all of those you mentioned The 14,000 I have is diamond paste and I use it on stones like the Montana I just posted in the lepidolite thread. Montana agates sometimes I find have a very thin layer cover tiny pin holes and diamond paste seems to work the best at removing them.
Post by hummingbirdstones on Jul 9, 2024 18:53:50 GMT -5
If you go up to 14,000, it will really pop. Do you have a spin-on lap on the end of your machine? A 14,000 diamond pad or either a cerium oxide or tin oxide pad on the end would finish it off nicely. I believe cerium is what jasoninsd uses on his. Jason, correct me if I'm blowing smoke. Yes I have all of those you mentioned The 14,000 I have is diamond paste and I use it on stones like the Montana I just posted in the lepidolite thread. Montana agates sometimes I find have a very thin layer cover tiny pin holes and diamond paste seems to work the best at removing them. Cool. You should be all good.
dreamrocks
Post by dreamrocks on Jul 9, 2024 18:54:55 GMT -5
I have tin oxide that may bring it to front. I’ll wait for a day when we’re not having thunderstorms every half hour and get my flat diamond laps out and clean up the bottom. I really like the looks of all those needles hidden underneath.
After I do that and give a proper touch up I’ll put some polish to it probably tin oxide and see what happens then. Got to make the gold colors pop!
Post by hummingbirdstones on Jul 9, 2024 19:15:53 GMT -5
I have tin oxide that may bring it to front. I’ll wait for a day when we’re not having thunderstorms every half hour and get my flat diamond laps out and clean up the bottom. I really like the looks of all those needles hidden underneath. After I do that and give a proper touch up I’ll put some polish to it probably tin oxide and see what happens then. Got to make the gold colors pop! Please post a photo when you're finished with it!
dreamrocks
Post by dreamrocks on Jul 9, 2024 19:19:50 GMT -5
I have tin oxide that may bring it to front. I’ll wait for a day when we’re not having thunderstorms every half hour and get my flat diamond laps out and clean up the bottom. I really like the looks of all those needles hidden underneath. After I do that and give a proper touch up I’ll put some polish to it probably tin oxide and see what happens then. Got to make the gold colors pop! Please post a photo when you're finished with it! Will do
