Post by beefjello on Feb 22, 2013 19:32:57 GMT -5
Post by Deleted on Feb 22, 2013 19:38:49 GMT -5
Nice score Brian. I seen the same add, but when I seen it was on your side of town I knew I could not beat you to it. :-)
Tim
Post by Drummond Island Rocks on Feb 22, 2013 19:42:51 GMT -5
Nice bunch of rocks and killer deal on the combo unit. were you lucky enough to have one of the new blades fit on the combo?
Post by jamesp on Feb 22, 2013 19:47:06 GMT -5
I want to see how many acres your rock collection covers beef.That is a fine $75 purchase!!
Post by rockpickerforever on Feb 22, 2013 20:55:00 GMT -5
Beef, is that a 600 grit diamond faceting lap in the first pic? Got any plans for it? Dang, but you always get the killer stuff... Nice score!
Tim, I feel sorry for you - so close, yet so far away from getting the goods before Beef can get to them. Jean
Post by Pat on Feb 22, 2013 21:11:09 GMT -5
You gotta be quick!
What's the rock with the big red dots?
Post by rockpickerforever on Feb 22, 2013 21:32:31 GMT -5
Looks to me like Mary Ellen Jasper (aka - stromatolite, fossilized algae) Jean
Post by Pat on Feb 22, 2013 21:43:45 GMT -5
Seems I am always drawn to stromatolites/gunk and Dino bones. Interesting and pretty. Thanks for the ID.
Post by mohs on Feb 22, 2013 22:12:21 GMT -5
Those rocks could have been next door and Beef would have beat me to it! just down the block and all that rock just shaking my head in disbelief mohstly
Post by Peruano on Feb 23, 2013 10:59:28 GMT -5
Great scores. It takes creative searching to hit all of the CL postings. But the obtuse ones often represent the best bargains. That is one big machine. Tom
Post by jamesp on Feb 23, 2013 11:13:52 GMT -5
It makes me wonder Pat,if you came back in another life-pond scum?sewer monster?stromboli?It scares me too,i am attracted to similar forms.Chalk it off to healthy genes?:>
Post by beefjello on Feb 25, 2013 19:23:18 GMT -5
Thanks guys 'n gals ;D So the previous owner obviously cut with water, and let it sit in the tank forever This pic is after scraping most the rust off. It's marinading in liquid wrench, but I'm not so sure I'll be able to bust this nut Chuck this is a 10" and the larger blade from the previous score is 12". I do have extra 10" blades if I can ever get this apart. Jean the lap is 600 grit diamond, 8" by 3/8".. heavy sucker. Is that a faceting lap? Need it? Thanks for the ID on the Mary Ellen.. this is the first piece I've ever had and wasn't sure what it was. Appreciate it everyone!
Post by Deleted on Feb 25, 2013 19:34:38 GMT -5
Hi Brian,
You should try that molasses trick that someone posted a while back, just fill up the reservoir and let it sit for a few days. Looks like a fun project.
Tim
Post by beefjello on Feb 25, 2013 19:39:32 GMT -5
Wow thanks Tim.. if the spray stuff don't break it loose I'll give it a shot!
Post by Pat on Feb 25, 2013 19:57:58 GMT -5
I understand Coca Cola can eat a hole in your stomach; maybe soaking your blade in coke would do the trick.
Post by rockpickerforever on Feb 25, 2013 21:19:39 GMT -5
Brian, the lap could probably be used either with a faceter or a lapper. I picked up an old Lee Lapidaries faceting machine two or three years ago at one of our club's silent auctions. It only came with one lap, which was left uncovered while my better half was grinding some steel. The steel chips landed on the lap, rusted and pockmarked the surface, pretty much wasting it. Not something you'd want to cut facets with, anyway. I just took a look at it, and I'm not sure what grit it is, you can't read the center label any more.
At a local swap meet about a year ago, we came across a guy that was selling what he thought were grinding wheels - we knew better! He was asking $5 each for them, we didn't bother to negotiate a lower price. We picked up the two Crystalite Diamond faceting laps, a 260 and a 1200, brand new, never used, still in the box. In one of the boxes was a brochure from Pacific Test Specialties, dated Spring 1973. On the outside of the box is stamped the cutting sequence. It goes from 260 (med) straight to 1200 (fine). I've haven't used the machine yet, but I'd seriously like to learn (I've been buying faceting rough ever since I got the faceting machine;)) Just from making cabs, I would think having 600 between those two steps would be an improvement.
You said it was 8" x 3/8" - thick, I'm guessing. Is the lap itself steel or aluminum? Or is it black phenolic with a topper? From the photo it looks like metal, and you said it was heavy - so proably steel. And what is the hole diameter? I'd need it to be 1/2 inch. Yeah, let me know if you'd like to part with it.
Here's an article that was emailed to me a while back about penetrating oils:
So if the penetrating oils and molasses don't bust that nut loose, you may want to try the 50/50 mix of ATF and acetone. If all else fails, cut into the nut from one of the flats, CAREFULLY! How was the rest of the cabinet, as far as rust goes?
Let me know what you'd want for the lap. Thanks, Brian. Jean
Post by sandsman1 on Feb 26, 2013 23:12:21 GMT -5
if all else fails hit it with heat grab a bottle torch and heat it up and let cool a few time a few taps with a steal hammer and it should break loose -- you got a great haul there man wtg
Post by beefjello on Feb 27, 2013 19:28:51 GMT -5
Interesting article Jean, thanks! Hmm.. I have a quart of atf, and Christa has a bottle of nail polish remover (same as acetone I think). Haven't checked progress of the Liquid Wrench past couple days, but I have some back up ideas now.. and thanks Sands for the heat up tip! Jean the lap is steel, and weighs over 5 pounds. The hole is 1/2". The business side is a little stained, looks like oil was spilled on it in the past, but in the sun I can see lots of diamond there.. not sure if it was ever used at all. I'll send you a PM
Post by rockpickerforever on Feb 28, 2013 10:22:38 GMT -5
Brian, PMed you back. Jean
The Dad_Ohs
Take me to your Labradorite!!
Member since September 2012
Post by The Dad_Ohs on Feb 28, 2013 14:11:45 GMT -5
if you sprayed it with anything to help loosen the rust I would try a pin point torch (small very hot flame) and heat just the outside corner on one edge of the nut then try to turn it... it just might spin right off... be prepared for a lot of popping rust when you do this!!
