Post by jamesp on Sept 10, 2013 19:01:43 GMT -5
Post by Deleted on Sept 10, 2013 19:13:18 GMT -5
suuuuhhhweeeeet!!! Totally digging the steampunk biker shades too! Plus the hourglass coral is out of this world. Rock the eff on!!!
Post by jamesp on Sept 10, 2013 19:18:07 GMT -5
Extra 50 degrees took it over to another level. Thank ya
Those are welding glasses. They are old. Got a pair that looks like new. The glass is pitted bad.
Post by Deleted on Sept 10, 2013 19:37:03 GMT -5
yeah, slag metal drops stick to glass real nice huh?
Post by kk on Sept 10, 2013 19:45:52 GMT -5
James, name your price, I wanna try the first and fourth from the left.
Post by jamesp on Sept 10, 2013 19:47:40 GMT -5
I think i arc weld over them Scott when i am torching and welding. They are for torch only. Yea. They are sitting here and they have slag drops on the inside of the lens just as much as the outside. I am hoping i was not wearing the then LOL
Post by jamesp on Sept 10, 2013 19:49:39 GMT -5
I will put them in your goodie pile Kurt. Free as a gift, $637,925.63 if you insist on buying.:> I see some very sexy shady sister's bodies in those...
Thunder69
Thunder 2000-2015
Post by Thunder69 on Sept 10, 2013 20:01:33 GMT -5
The good oven kicks it up quite a few notches ...Those colors kick ass...John
Post by kk on Sept 10, 2013 20:16:41 GMT -5
Then you better have a desirable design on mind for a carving for yourself.
Post by Drummond Island Rocks on Sept 10, 2013 20:23:35 GMT -5
just when I thought it couldnt get better you turn up the heat. nice show man.
chuck
Post by Pat on Sept 10, 2013 20:31:43 GMT -5
WOW! Those are the prettiest colors yet. The reds in your hand are gorgeous. And it was a mere extra 50 degrees more. I think our regular kitchen oven goes to 600.
Was 600 the temperature you used to get these beauties?
panamark
Member since September 2012
Post by panamark on Sept 10, 2013 21:44:48 GMT -5
Those are fantastic James. I wonder what another 50 degrees would do, LOL. You know how guys always want to push until destruction. Didn't one of the smokers on Waterworld wear those same googles?
The Dad_Ohs
Take me to your Labradorite!!
Post by The Dad_Ohs on Sept 10, 2013 21:54:19 GMT -5
out of curiosity, could you have broken that big piece before cooking???
or were you just cooking to see what would happen, then broke it open after??
Tom
Post by Tom on Sept 10, 2013 21:59:01 GMT -5
Really nice coral James. I am not sure how long you cook them for but if it's not hours and hours you could try to cook them in a self cleaning oven. I think the temp gets up to 900 plus degrees, a hell of a lot hotter than the hottest cooking setting anyway:). Beautiful material anyway!
Post by quartz on Sept 10, 2013 23:33:44 GMT -5
Wow, lots o oohh's & aahh's here. Thanks for the show. Glad to hear and see that new oven is working well. Larry
Post by jamesp on Sept 11, 2013 1:59:23 GMT -5
John, i knew the kitchen oven was not quite hot enough.
My friend Stan(Stansknives) cooked some for me. I would say it went to 650 on the coral. The grainy coral got deep color and the glassy coral fractured.
So the 650 was ok for the grainy stuff. 550-600 for the glassy texture. And the books say 550-650 depending on grain size.
This weld rod oven is about perfect. It is rated at only 550, but it is hotter than that.
Well, most of you flint knappers use industrial ovens. I learned from you guys. Knappers are king of cooking rock. Thanks for looking
Post by jamesp on Sept 11, 2013 2:25:24 GMT -5
Kurt- Seeing your workmanship is payment enough. Your carving is certainly another level. Chuck-I was aware there was color advancement in the coral career. Just now getting around to the right oven. Pat-The top temp is a bit nebulous on an electric oven. Do not believe what they say. Best thing to do is stick known rock in there and cook it. Cooking rock is slow heating to your desired top temp, then hold to soak, and then slowly cool. If you do not hit the color changing temp you may get no change at all. Too hot and you will get fractured junk. When cooking under a camp fire a 5 minute gust of wind can fracture the whole batch quickly by raising the temp too quickly. Best to cook in an electric oven Mark-That was me on Waterworld. Thanks for noticing.
Post by jamesp on Sept 11, 2013 2:40:34 GMT -5
Mario-Yes you could have cooked the whole volleyball sized rock. I can easily cook basketball size in that oven.
Here is the problem.
If you cook a big coral head you got to raise the temp very very slowly to bring the heat in gradually or else you will pop it into numerous chunks(called exploding). I had no interest in running the oven like 2 days and have no saw to cut a chunk that big so i broke it into smaller pieces that could certainly be slabbed and cabbed.
The oven is only 1000 watts but is well insulated and efficiently shaped. The kitchen oven i was using is 2000 watts and would not get this hot.
This oven is cheap to operate. I would say the element was on for a total of 6 hours during the 24 hour bake job. And will cook 200 pounds at a time.
Post by jamesp on Sept 11, 2013 8:04:48 GMT -5
Tom-Noviculite is cooked at 800-900F. It is about the hottest i have ever seen a flint type quartz being cooked. Larry-I owe you for the Mcdermitt. Hope i can get to the river to collect more. Will try cooking some of that too. The thermostat is wacked and has a min temp of 330F. So i plug it for 15 minutes per hour for the first 3 hours to dehydrate. The company says the thermostat should hold 130 dergrees. Mine is messed up. But It costs $285 so i will live with it. This thing is 40 years old. And had no scale. So i have been putting the temps w/magic marker around the dial.And the knob came off of an old washing machine.
grayfingers
Member since November 2007
Post by grayfingers on Sept 11, 2013 8:33:42 GMT -5
Wow, sweet stuff! Such dramatic transitions in the colors. I will be excited to see what Kurt will do with this material, he has taken Montana agates to a new and unique level, and I am sure he will make some stunning works! I inherited a kiln, think I might have to cook some rocks this winter.
