Post by Deleted on Jun 3, 2016 9:29:17 GMT -5
A friend whom lurks but doesnt have a profile asks if any of you viking users can offer advice about the belts.
He says they wear out fast, and where do yiu get them?
riverbendlapidary
Member since September 2006
Post by riverbendlapidary on Jun 3, 2016 10:37:16 GMT -5
Post by jamesp on Jun 3, 2016 12:10:36 GMT -5
Post by MrP on Jun 3, 2016 12:24:05 GMT -5
I have bought the Recommended belt and they last a long time . I have had a set last a year but they have run less then that also, but way out last anything else I have found....................................MrP
Post by catmandewe on Jun 3, 2016 13:00:16 GMT -5
I have 3 different ones and I get my belts from Diamond Pacific and I have not had to change mine yet.
Post by Deleted on Jun 3, 2016 14:00:33 GMT -5
I have 3 different ones and I get my belts from Diamond Pacific and I have not had to change mine yet. In how long?
colliel82
Member since November 2007
Post by colliel82 on Jun 3, 2016 22:17:43 GMT -5
I also order mine from Diamond Pacific. I think its around $20 for 2, but they last me about a year.
Post by jamesp on Jun 4, 2016 5:30:37 GMT -5
My belts have to be stretched a good bit to get on the pulleys. Pretty close to a 3 inch circle. May try next size up like 3.25 or 3.5 next time. Pretty sure it would prolong life and still do it's job. There are o-rings designed specifically for being drive belts. Certain they would last longer. Of course a bag of fifty will last longer than I.
Size specs:
O-Ring, Buna N, AS568A Dash Number 337, Fractional Width 3/16", Actual Width 0.210", Color Black, Cross Section Shape Round, Inside Dia. 3", Actual Inside Dia. 2.975", Outside Dia. 3-3/8", Radius -, Axial Thickness -, Thickness -, Durometer Rating Medium Hard, Durometer 70 Shore A, Temp. Range -40F to +250F, Meets/Exceeds SAE J200, ASTM D2000, Includes -, Package Quantity 50 RestrictionsNote: Additional O-ring durometers and materials are available; on DrillSpot.com , search for "Buna N 90 durometers O-rings, VIton 90 durometer O-rings, Silicone O-rings, or EPDM O-rings." Buna N and Viton O-RingsStandard O-rings serve a variety of uses, including sealing valves, faucets, flanges, and engines. Round cross-section. Medium-hard.Meet SAE J200, ASTM D2000.
Post by jamesp on Jun 4, 2016 5:40:28 GMT -5
This company sells 3/16" o-rings in 1/8 inch increments. Mold IDen 1-340 1-341 1-342 1-343 1-344 Nominal Dimensions I.D. O.D. C/S Actual Dimensions I.D C/S 3.350 ±.024 .210 3.475 .210 3.600 ±.028 .210 O.D. (Ref) Specification 3.770 AS568-340 3.895 AS568-341 4.020 AS568-342 Precision Associates, Inc. 3800 N. Washington Ave. Minneapolis, MN 55412 1234 Phone: (612) 333-7464 Fax: (612) 342-2417 Toll: (800) 394-6590 www.PrecisionAssoc.com1-340 1-342 3 3/8 3 1/2 3 5/8 3 3/4 3 7/8 3 3/4 3/16 3 7/8 3/16 4 3/
Post by jamesp on Jun 4, 2016 5:47:34 GMT -5
I also order mine from Diamond Pacific. I think its around $20 for 2, but they last me about a year. One year, that is great. Mine last about 2 weeks. Machine runs a good bit with no drive belt. Lost time-no good. Best to have them last. And avoid the hassle of replacing them.
Post by johnjsgems on Jun 4, 2016 7:58:31 GMT -5
Diamond Pacific is the manufacturer of that line of tumblers.
Post by catmandewe on Jun 5, 2016 15:44:01 GMT -5
I have 3 different ones and I get my belts from Diamond Pacific and I have not had to change mine yet. In how long? Been running one for 3 years now with no belt changes. I do about 200-400 lbs of tumbles per year to give away to the kids, I use the vikings for finish only and do the rough grind in a 100 lb rotary tumbler. Works good for me.
Post by Deleted on Jun 5, 2016 15:48:15 GMT -5
Been running one for 3 years now with no belt changes. I do about 200-400 lbs of tumbles per year to give away to the kids, I use the vikings for finish only and do the rough grind in a 100 lb rotary tumbler. Works good for me. So only a few months of actual use. From what I read here and hear from my lurking buddy, the viking is best sold off or used infrequently. Seems like POS. Lurking buddy extends gratitude to all whom answered. So do I, reinforced my desire to build not buy....
riverbendlapidary
Post by riverbendlapidary on Jun 8, 2016 12:50:43 GMT -5
let me know if he wants to sell it!
Post by jamesp on Jun 8, 2016 15:35:18 GMT -5
Been running one for 3 years now with no belt changes. I do about 200-400 lbs of tumbles per year to give away to the kids, I use the vikings for finish only and do the rough grind in a 100 lb rotary tumbler. Works good for me. So only a few months of actual use. From what I read here and hear from my lurking buddy, the viking is best sold off or used infrequently. Seems like POS. Lurking buddy extends gratitude to all whom answered. So do I, reinforced my desire to build not buy.... Deadly on agate and Mohs 7. Cup a sugar, cup a water, tbsp of AO 500 and come back 3 days and open. Does big rocks with lots of media. Not selling mine. Like it lots. Stinks on soft rocks except when dry tumbling. However, if adjusted slower it may do soft stuff. I would not be confident building a vibe that does not pit glass or obsidian. Just looking at the foundation of a Lot-O tells me some higher mechanical technology is lurking behind the scenes.
Post by Deleted on Jun 8, 2016 16:06:54 GMT -5
let me know if he wants to sell it! Thanks JR. He sells equipment occasionally, I'm sure he will get a good price if he does sell.
Post by Deleted on Jun 8, 2016 16:08:56 GMT -5
I would not be confident building a vibe that does not pit glass or obsidian. Just looking at the foundation of a Lot-O tells me some higher mechanical technology is lurking behind the scenes. I hope by end of summer I can prove you wrong! I have a bunch of Davis Creek here. That is just to much belt changing for me.
Post by jamesp on Jun 8, 2016 16:14:20 GMT -5
I would not be confident building a vibe that does not pit glass or obsidian. Just looking at the foundation of a Lot-O tells me some higher mechanical technology is lurking behind the scenes. I hope by end of summer I can prove you wrong! I have a bunch of Davis Creek here. That is just to much belt changing for me. Belt slips over pulleys. No tools. Easy. Yes, please rise to that challenge. Very anxious to see it.
Post by Deleted on Jun 8, 2016 16:17:15 GMT -5
I hope by end of summer I can prove you wrong! I have a bunch of Davis Creek here. That is just to much belt changing for me. Belt slips over pulleys. No tools. Easy. Yes, please rise to that challenge. Very anxious to see it. quartz already has the machine. Larry have you tried glass?
Post by jamesp on Jun 8, 2016 17:07:40 GMT -5
Belt slips over pulleys. No tools. Easy. Yes, please rise to that challenge. Very anxious to see it. quartz already has the machine. Larry have you tried glass? If anyone can get er done Larry can. His a revolutionary design.
