Post by jamesp on Sept 11, 2016 9:57:53 GMT -5
A block of crazy lace @ 1 pounds 7 ounces Same block after grinding. Lost 4 ounces and now 1 pound 3 ounces. Wet it to see it's stuff. Got a little bot cavity. Selection of other rocks to run it with. Need about 13 pounds for 15 pound barrel. No smalls, just fairly large coral. Can add smalls later after this chunk is done shaping. Smalls over rated for roughing in my mind. Shaping ? Not really, just removing the deep grinding marks from the coarse grinder. The grinder shaped it. The coral needs about 8 weeks shaping, the crazy lace should be ready for the vibe in 4 weeks. Will shape using SiC 30 added every 3 days. Will thin slurry as needed, probably after 9 days or just before 4th 30 grit addition. Will run the last 30 grit addition about 12 days to break it down to ~500 grit. Then to the vibe by itself with AO 500 and sugar with agate pea gravel for about 4 days. May run 24 hours after that with AO 14,000 polish and Borax if polish is not up to snuff. Enthusiastic onlookers
Post by jamesp on Sept 11, 2016 9:59:46 GMT -5
Donation appreciated rockpickerforever. Take a deep breath Jean, this is the last of the crazy lace brick.
Post by jamesp on Sept 11, 2016 10:06:39 GMT -5
For doing tumbles from 1 to 3 pounds I wish I had a bunch of 6 pound barrels. Rolling 2 stones that size in one barrel is a challenge in avoiding impact damage. Thinking about retiring the two worn out 15 and two worn out 20 pound barrels and figuring on a design for 6-8 six pound barrels.
Post by captbob on Sept 11, 2016 11:04:08 GMT -5
Jean gave you that crazy lace?
I hope you thanked her!
Post by jamesp on Sept 11, 2016 12:22:21 GMT -5
Jean gave you that crazy lace? I hope you thanked her! I believe I thanked Jean rockpickerforever captbob.
Post by Jugglerguy on Sept 11, 2016 15:11:45 GMT -5
I love crazy lace! That should be really nice when you get done with it. It's even prettier than your finger.
Post by jamesp on Sept 11, 2016 15:26:46 GMT -5
I love crazy lace! That should be really nice when you get done with it. It's even prettier than your finger. Thanks Rob. The finger has been tumbled many times. BIG improvement on the new avatar.
Post by orrum on Sept 11, 2016 16:38:58 GMT -5
Hey Jim how much SC 30 do you put in a 12-15 lb barrel?
Post by Drummond Island Rocks on Sept 11, 2016 17:58:07 GMT -5
The rock tumbler in me says that will look great tumbled but the cabber in me says shame on you for tumbling great cab stock. I have been known to tumble stuff like that only to chop them up later for cabs.
Post by jamesp on Sept 11, 2016 18:18:10 GMT -5
Hey Jim how much SC 30 do you put in a 12-15 lb barrel? Just a cup. And then another cup 3 days later. And another 3 days later. on and on. Often do not do a clean out. Just pour water in the barrel, shake and pour liquid back out to thin slurry. Or add water and let it roll for a few minutes and then pour liquid out if the slurry is really thick. Let the barrel sit a minute for grit to settle and then pour liquid out. Adding a cup every 3 days because it breaks down every 2-3 days. So the early grit additions get run a long time.
Post by jamesp on Sept 11, 2016 18:22:04 GMT -5
The rock tumbler in me says that will look great tumbled but the cabber in me says shame on you for tumbling great cab stock. I have been known to tumble stuff like that only to chop them up later for cabs. Chuck I see your point Chuck. If you cab, cut that fine stuff up. Tumbled or not. There is a 'gem' value in a big hunk of fine stone tumbled. Ever seen a sphere that would yield 30 cabs ? Same game.
Post by Drummond Island Rocks on Sept 11, 2016 18:42:27 GMT -5
The rock tumbler in me says that will look great tumbled but the cabber in me says shame on you for tumbling great cab stock. I have been known to tumble stuff like that only to chop them up later for cabs. Chuck I see your point Chuck. If you cab, cut that fine stuff up. Tumbled or not. There is a 'gem' value in a big hunk of fine stone tumbled. Ever seen a sphere that would yield 30 cabs ? Same game. Good lace agate that size is getting hard to come by. Might be 10-12 nice pendants in that chunk but lots of labor involved too. I bought two tumbled pieces of ocean jasper last year at a show and sliced them up for cabs/wraps. Chuck
Post by jamesp on Sept 11, 2016 19:53:03 GMT -5
I see your point Chuck. If you cab, cut that fine stuff up. Tumbled or not. There is a 'gem' value in a big hunk of fine stone tumbled. Ever seen a sphere that would yield 30 cabs ? Same game. Good lace agate that size is getting hard to come by. Might be 10-12 nice pendants in that chunk but lots of labor involved too. I bought two tumbled pieces of ocean jasper last year at a show and sliced them up for cabs/wraps. Chuck That rock has a couple of fractures running deep. Would have probably cause some havoc if slabbed Chuck.
Post by Drummond Island Rocks on Sept 11, 2016 20:05:07 GMT -5
With your pre-grind it should only take a couple weeks in stage one then a week in the vibe. Quick tumble. Looking forward to the results.
Post by jamesp on Sept 12, 2016 5:29:03 GMT -5
With your pre-grind it should only take a couple weeks in stage one then a week in the vibe. Quick tumble. Looking forward to the results. Chuck There is a quicker reward in pre-grind no doubt. I am retiring from large barrels and heavy loads to smaller barrels with smaller loads. And tumbling one big pre-shaped specimen in each small barrel. Focus on some more exotic material for said large tumble. My PVC barrels are about worn out so am looking at some 6-8 pound capacity 6" PVC barrels with the same easy to open 4" opening w/the rubber cap. Maybe doing some giant cabs 1-2 inches thick and other shapes. Said large tumble may be a target for the saw one day per Chuck method if making cabs came of interest 'no rock is safe'
Post by rockpickerforever on Sept 12, 2016 16:08:03 GMT -5
Rabble rouser! (Or should I say, REBEL rouser?)
Why, yes, he did, now that you mention it. Several times!
Post by rockpickerforever on Sept 12, 2016 16:10:27 GMT -5
Yes, they all look very enthused!!! (sleeping pills???) Just wondering, what did you name the new puppy? RR #4? Actually, I guess the question should be, What do you call her? Let's see, what type of vermin would you call her? Ya already got a maggot. Lol.
Donation appreciated rockpickerforever . Take a deep breath Jean, this is the last of the crazy lace brick.
You are, once again, so very welcome. So, James, was this the last third of the big block I sent ya? Can't wait to see how this tumbles and shines up in your divided vibe.
Post by captbob on Sept 12, 2016 16:14:20 GMT -5
*snicker*
Post by jamesp on Sept 12, 2016 18:21:18 GMT -5
A mud theme on this one rockpickerforever. Muck-Mud Pie-Claypup-etc There seems to be a delay in naming her. She is a wild child and does find water and mud. If she continues urinating in the house 'Yellow Rain'. she is on right
Post by jamesp on Sept 12, 2016 18:24:54 GMT -5
captbob a rebel rouser?, naw no way
