Post by jamesp on Sept 30, 2016 7:31:41 GMT -5
These will make a lap of the future. For the home builder. These are 8 inches, getting bigger. Certain they will start making even bigger ones.
Post by orrum on Sept 30, 2016 7:58:03 GMT -5
Hey Jim where you find yhose? I have a ancient 8 inch flat lap!
wampidytoo
Add 5016 to my post count.
Member since June 2013
Post by wampidytoo on Sept 30, 2016 8:29:31 GMT -5
Dayum, I have been thinking about moving up to 6" from 5" but those will fit my machine if they make the standard 5/8" female thread backer pad. My biggest problem with the five inch is polishing slabs so a set of those just for slabs would be way better. Thanks for the heads up. Jim
Post by jamesp on Oct 1, 2016 7:24:22 GMT -5
Dayum, I have been thinking about moving up to 6" from 5" but those will fit my machine if they make the standard 5/8" female thread backer pad. My biggest problem with the five inch is polishing slabs so a set of those just for slabs would be way better. Thanks for the heads up. Jim Hey Jim where you find yhose? I have a ancient 8 inch flat lap! I have not purchased them Bill. I only located them in this link. Yes Jim, 8 inches is enough for slab work. Nothing cuts like those impregnated pads. Link www.china-superabrasives.com/Flexible_polishing_pads.htm
vwfence
Post by vwfence on Oct 1, 2016 9:48:46 GMT -5
I have a set of 7 inch that i plan to use on a variable speed polisher for doing slabs . Once i get it put together i will try and get some pictures . I bought mine on Ebay i think . it was a while ago so i forget . It could have been Amazon if Ebay doent have them
Post by Psycho on Oct 1, 2016 17:24:40 GMT -5
Those would work great on my diy angle lap. I bought a 3" inch set to make a experimental cab grinder. Do those 8" pads have velco back like the smaller ones ?
Post by orrum on Oct 1, 2016 18:18:21 GMT -5
I don't see any prices...
Post by spiceman on Oct 1, 2016 20:56:26 GMT -5
Yep, no prices. Looking at the website is a little like looking at a harbor freight catalog. I wonder if you give them the site maybe they can order it for you.
vwfence
Post by vwfence on Oct 1, 2016 22:11:52 GMT -5
they are velcro backed . I paid a bit over 50 dollars for 7 pads including dlivery
Post by jamesp on Oct 2, 2016 2:35:04 GMT -5
I don't see any prices... Those would work great on my diy angle lap. I bought a 3" inch set to make a experimental cab grinder. Do those 8" pads have velco back like the smaller ones ? I don't know about ordering and velcro. Just glad to see that they are making them larger. Aliexpress is a bit friendly to order from. However there is some credit card scams ordering from China. Call Pedro at dtiblades.comHe may have a source. He is lapidary friendly diamond tool supplier.
Post by jamesp on Oct 2, 2016 2:35:57 GMT -5
they are velcro backed . I paid a bit over 50 dollars for 7 pads including dlivery Supplier vwfence ?
Post by orrum on Oct 2, 2016 3:16:51 GMT -5
Good price!
hh5
Member since January 2012
Post by hh5 on Oct 2, 2016 10:28:55 GMT -5
Never thought of these for polishing slabs but sounds like it would work. Love experimenting.
Post by jamesp on Oct 2, 2016 11:08:25 GMT -5
This is a 6 station. 100-200-400-800-1500-3000. $40 Walmart grinders. Face plate home made. The face plates are the trick. Grinded off the velcro and glued them to the face plates. Grinder at 3600 RPM. Perfect for rubber pads. About 10 years old. Original pads, they last forever on hard rock, not so much on concrete. Grinders finally suffering from rust bearing disease, need a little push to get them going. Can polish 3 inch slab in a few minutes off of well adjusted power feed saw. Balancing water takes a bit off adjusting, once flows are balanced it is all rock and roll. Wish the pads were bigger. Wear bathing suit. More photos: www.flickr.com/photos/67205364@N06/sets/72157671251912854
Post by jamesp on Oct 2, 2016 11:13:15 GMT -5
Where to buy lathe turned face plates ?? I welded mine from giant washers and 5/8 nuts. Some did not run true and cause bouncing which is bad. Love that machine. Polished some big stuff on it.
Post by captbob on Oct 2, 2016 11:23:45 GMT -5
Believe they make big pads like those in the OP for grinding/polishing terrazzo floors. Diamond floor buffing pads like a up to a couple feet in diameter. For your really BIG slabs!
Post by Deleted on Oct 2, 2016 11:34:14 GMT -5
hh5
Post by hh5 on Oct 2, 2016 14:34:44 GMT -5
I have seen a lot of different ways to polish slabs but this one is for me. Great pictures jamesp, made me realize this is doable. Do you think those grinders would handle the 8" pads and polishing say a 6" slab?
Post by Deleted on Oct 2, 2016 15:00:26 GMT -5
I have seen a lot of different ways to polish slabs but this one is for me. Great pictures jamesp, made me realize this is doable. Do you think those grinders would handle the 8" pads and polishing say a 6" slab? Yes. No doubt. You will want to buy the solid backer too, so you have solid flat to work on. And be careful. When the larger grits cut, thousands of tiny diamonds grab the stone. You will absolutely notice the action. Could cause accidents.
vwfence
Post by vwfence on Oct 2, 2016 20:34:46 GMT -5
James :I bought my pads on Ebay from the seller Tool4stone . they have faceplates but i didnt buy one as the polisher im going to use came with a face plate plus i have some fleece bonnets with it . by useing the polisher i have either 4 or 5 speeds to work with . I will be finishing up the brackets to mount it here soon and i will send you a picture . The polisher came from harbor freight when they were on sale for less than 30 dollars
