Post by woodman on Nov 17, 2018 21:20:58 GMT -5
I got some agate from Roy a few weeks ago and I finally got around to making a few cuts. This one will polish up REAL fine. 5 inches at the widest spot.
Agate
Nov 17, 2018 21:38:08 GMT -5
Post by rockjunquie on Nov 17, 2018 21:38:08 GMT -5
Sweet!
Agate
Nov 18, 2018 0:43:35 GMT -5
Post by fernwood on Nov 18, 2018 0:43:35 GMT -5
Nice agate.
mossyrockhound
Member since January 2011
Post by mossyrockhound on Nov 18, 2018 1:55:10 GMT -5
Fine piece of Brazilian (?).
Agate
Nov 18, 2018 8:22:30 GMT -5
Post by miket on Nov 18, 2018 8:22:30 GMT -5
Love it!
Post by Fossilman on Nov 18, 2018 10:22:29 GMT -5
Beautiful cut...... Roy does have great material..
Agate
Nov 18, 2018 10:34:47 GMT -5
Post by woodman on Nov 18, 2018 10:34:47 GMT -5
Sorry for the poor photo, today is the day to build a fire in the shop and do some work, should be able to get it polished. the cut is smooth enough so I will go directly to the bull wheel and get it sanded. and then polished. When viewed in person, it has some iris effect, that should pop out when polished. this slab is a bit over 1/4" Thick I will make one more slice a bit thinner.
Post by woodman on Nov 18, 2018 17:47:30 GMT -5
It took a real good polish.
Agate
Nov 18, 2018 20:02:24 GMT -5
Post by miket on Nov 18, 2018 20:02:24 GMT -5
Daaaaaaaang!
Agate
Nov 19, 2018 15:25:31 GMT -5
Post by MsAli on Nov 19, 2018 15:25:31 GMT -5
That is very nice!
Agate
Nov 19, 2018 22:29:40 GMT -5
MsAli likes this
Post by woodman on Nov 19, 2018 22:29:40 GMT -5
The deer are getting too tame!!
Post by MsAli on Nov 20, 2018 15:11:00 GMT -5
The deer are getting too tame!! I just now saw that
Post by MsAli on Nov 20, 2018 15:11:40 GMT -5
That's what happens when you show us pretty rocks, didn't even look at the background!
Post by RWA3006 on Nov 20, 2018 23:57:10 GMT -5
I saw that deer pretty quickly. Reminds me of the rogue that savaged my weeping fir tree the other day with antlers. Where did that nice agate come from?
Agate
Nov 21, 2018 10:52:30 GMT -5
Post by woodman on Nov 21, 2018 10:52:30 GMT -5
I saw that deer pretty quickly. Reminds me of the rogue that savaged my weeping fir tree the other day with antlers. Where did that nice agate come from? I got some nice Brazilian agate from Roy and this is a slice of one. He has some nice stuff.
Agate
Nov 21, 2018 11:35:50 GMT -5
Post by roy on Nov 21, 2018 11:35:50 GMT -5
Sorry for the poor photo, today is the day to build a fire in the shop and do some work, should be able to get it polished. the cut is smooth enough so I will go directly to the bull wheel and get it sanded. and then polished. When viewed in person, it has some iris effect, that should pop out when polished. this slab is a bit over 1/4" Thick I will make one more slice a bit thinner. that would be awesome if it did have iris glad you like it cant wait to see it polished
Agate
Nov 21, 2018 11:36:41 GMT -5
Post by roy on Nov 21, 2018 11:36:41 GMT -5
Agate
Nov 21, 2018 11:39:35 GMT -5
Post by HankRocks on Nov 21, 2018 11:39:35 GMT -5
It took a real good polish. Very nice polish on that. You said you use a Bull Wheel initially to smooth it? How did you polish it.? I don't have a Bull Wheel. My approach is to polish a large piece(Brazilian or Petrified Wood) on the Vib-Lap, not as fast but does the job. After polishing the end, I cut it off and start the process again. One advantage is that as long as the piece is large I don't need any added weight to improve the grinding/polishing. For the smaller Brazilian I go ahead and cut slabs and then tumble them. Got 20 or so small Brazilian halves that I am trying to decide to use my 8" Expando Drum set up or to give them a go on the Vib Lap. Without the mass to aid it takes longer to grind/polish on the Vib Lap. Henry
Agate
Nov 21, 2018 14:28:41 GMT -5
Dr DG likes this
Post by woodman on Nov 21, 2018 14:28:41 GMT -5
It took a real good polish. Very nice polish on that. You said you use a Bull Wheel initially to smooth it? How did you polish it.? I don't have a Bull Wheel. My approach is to polish a large piece(Brazilian or Petrified Wood) on the Vib-Lap, not as fast but does the job. After polishing the end, I cut it off and start the process again. One advantage is that as long as the piece is large I don't need any added weight to improve the grinding/polishing. For the smaller Brazilian I go ahead and cut slabs and then tumble them. Got 20 or so small Brazilian halves that I am trying to decide to use my 8" Expando Drum set up or to give them a go on the Vib Lap. Without the mass to aid it takes longer to grind/polish on the Vib Lap. Henry I polish it on a large polishing machine, carpet on rotating 24 inch flat plate and cerium oxide.
Agate
Nov 21, 2018 14:31:47 GMT -5
Post by HankRocks on Nov 21, 2018 14:31:47 GMT -5
I polish it on a large polishing machine, carpet on rotating 24 inch flat plate and cerium oxide. I have seen your setup, do you put weight on the slabs. Does not seem like a 1/4 slab would have enough weight to allow for polishing or it takes a while.
