Post by miket on Jun 16, 2020 15:55:19 GMT -5
My wire finally came today so it's back to work. I'm trying to decide if I want to redo this- I love the cab, the wrap is ok...but the bail is meh. Any input would be appreciated. St. John's Flower Agate from hummingbirdstones . Thanks for looking!
NevadaBill
Post by NevadaBill on Jun 20, 2020 9:02:59 GMT -5
Hi Mike. I love the rock, and am challenged to spot the bail. It will ultimately be up to you if you decide to redo the wrap though. I know that there is not much I hate worse than pulling the whole thing apart and starting over...
Post by miket on Jun 20, 2020 9:57:30 GMT -5
Thanks Bill. I haven't decided, it wouldn't be the first time. 😁
Post by knave on Jun 20, 2020 9:59:14 GMT -5
Missed this. Sweet rock!!
Post by miket on Jun 20, 2020 10:00:52 GMT -5
Post by hummingbirdstones on Jun 20, 2020 22:11:44 GMT -5
I thought I had replied to this when you first posted it. Maybe I forgot to hit the post button.
Anyway, I think the stone looks like the St. John's Flower Agate that I put in the Traveling Slabbette box.
Post by miket on Jun 21, 2020 4:49:59 GMT -5
I thought of that when I first put this on, Robin...and after comparing the two I think you're right. I was waiting for someone to tell me I was wrong- it seems like I forget easily...too many rocks, I guess. Not. Thanks for the correction. And the stone! 😁
Post by hummingbirdstones2 on Jun 23, 2020 22:41:57 GMT -5
You did good with that rock. That was one of the best little chunks of St. Johns we've ever had.
By the time we started cutting things other than opal and learned about that rough those areas had apparently already been closed off. We got lucky and had a couple move to our area who had lived there. He had actually worked for SRP. They had a rough sale after they joined our club. That's how we got it.
Post by miket on Jun 24, 2020 9:27:23 GMT -5
Thank you, sir. It was definitely a nice slab! Unfortunately, this one has a fracture that seems to go all of the way through running across the middle of the stone to the binding on the bottom right side. I was going to rewrap it with silver but if I did that I would probably try to redo the cab, too and it might make it too small then. Any advice? I think the smaller cab that I did turned out better quality-wise but this one had more to look at. Here's how it turned out- forum.rocktumblinghobby.com/thread/91973/st-johns-flower-agate
Post by drocknut on Jun 25, 2020 12:49:10 GMT -5
I think it looks ok, although the fracture in it might cause it to break eventually so might be worth it to try to redo the cab and wrap. I have heard St John's Flower Agate is really fractury so might want to consider trying some "hot stuff" or "Starbond" to just stabilize the fracture instead of redoing the cab.
Post by miket on Jun 25, 2020 14:09:43 GMT -5
I think it looks ok, although the fracture in it might cause it to break eventually so might be worth it to try to redo the cab and wrap. I have heard St John's Flower Agate is really fractury so might want to consider trying some "hot stuff" or "Starbond" to just stabilize the fracture instead of redoing the cab. Thanks for the tip- I might just try to stabilize it because I like the position of the red "blotch" in the cab...
Post by drocknut on Jun 25, 2020 21:12:23 GMT -5
I think it looks ok, although the fracture in it might cause it to break eventually so might be worth it to try to redo the cab and wrap. I have heard St John's Flower Agate is really fractury so might want to consider trying some "hot stuff" or "Starbond" to just stabilize the fracture instead of redoing the cab. Thanks for the tip- I might just try to stabilize it because I like the position of the red "blotch" in the cab... It's worth a try at least.
