Post by catmandewe on Oct 1, 2021 21:42:27 GMT -5
When we were in Denver this year we ran across a killer deal on tumble size rutilated quartz so I came home with a full barrel. I am selling it for $12 a lb but will set the RTH price at $10 lb, 1 lb minimum, no maximum unless I run out. Absurdly low price for golden rutile! Some are large enough to be cabbed but most are tumbling size. Here are a few photos of some I have sold already, these are random pulls. The ones in the barrel are coated in mineral oil, I clean the oil off a bucket at a time so if I can keep up with it then they will be cleaned, if not you will get the oily ones. If you want some let me know how much you want and I can fix you right up. Tony
Post by orrum on Oct 2, 2021 7:19:50 GMT -5
Ohhh what pretty stuff and tumbles easy. Love to tumble quartz!
nursetumbler
Member since February 2022
Post by nursetumbler on Mar 18, 2022 20:59:58 GMT -5
When we were in Denver this year we ran across a killer deal on tumble size rutilated quartz so I came home with a full barrel. I am selling it for $12 a lb but will set the RTH price at $10 lb, 1 lb minimum, no maximum unless I run out. Absurdly low price for golden rutile! Some are large enough to be cabbed but most are tumbling size. Here are a few photos of some I have sold already, these are random pulls. The ones in the barrel are coated in mineral oil, I clean the oil off a bucket at a time so if I can keep up with it then they will be cleaned, if not you will get the oily ones. If you want some let me know how much you want and I can fix you right up. Tony catmandeweHello Do you still have any left?
quanterius
Member since January 2020
Post by quanterius on Mar 18, 2022 22:18:26 GMT -5
I’ll take 4 lbs off your hands. Looks like great stuff.
Post by catmandewe on Mar 19, 2022 21:16:37 GMT -5
I’ll take 4 lbs off your hands. Looks like great stuff. Ill pull them for you tomorrow. Tony
nursetumbler
Post by nursetumbler on Mar 19, 2022 22:39:57 GMT -5
catmandeweNew tumbler here. Is this an easy tumble for a newbie? If so, or relatively so, I'll take 5 pounds. I'm pretty good at following directions rather well if it's more intermediate to tumble. Send me a private message for more info
Post by catmandewe on Mar 20, 2022 0:11:26 GMT -5
catmandeweNew tumbler here. Is this an easy tumble for a newbie? If so, or relatively so, I'll take 5 pounds. I'm pretty good at following directions rather well if it's more intermediate to tumble. Send me a private message for more info These are pretty easy tumbles and they will come out fantastic. Ill send you a pm for invoice info. Tony
nursetumbler
Post by nursetumbler on Mar 27, 2022 21:37:23 GMT -5
Hi catmandewe I got to see the package. I am in love. Thank you for sharing with the group which actually gave me a chance to tumble this. Thank you
geezer
Member since April 2016
Post by geezer on Mar 28, 2022 7:19:44 GMT -5
Greetings! Any still available?
If so, I'll take 4 pounds too!
Post by catmandewe on Mar 28, 2022 13:30:25 GMT -5
Greetings! Any still available? If so, I'll take 4 pounds too! I sent you a private message. Tony
lparker
Member since March 2008
Post by lparker on Mar 28, 2022 16:29:49 GMT -5
Tony, I'll take a large flat rate box...oily is ok.
rockbrain
Member since January 2022
Post by rockbrain on Mar 28, 2022 16:47:57 GMT -5
I'd like to get about 5 lbs if still available. If possible I'd like some larger ones as I'm going to try and coax a few cabs out of it. Thanks!
allbetzoff
Member since November 2020
Post by allbetzoff on Mar 29, 2022 10:04:54 GMT -5
Hi there. I'll take 2 pounds if available. Thanks!
Post by hummingbirdstones on Mar 29, 2022 10:07:50 GMT -5
Post by catmandewe on Mar 29, 2022 16:40:28 GMT -5
Tony, I'll take a large flat rate box...oily is ok. Lee, I will get it filled up for you. I'd like to get about 5 lbs if still available. If possible I'd like some larger ones as I'm going to try and coax a few cabs out of it. Thanks! rockbrain, I sent you a private message. Hi there. I'll take 2 pounds if available. Thanks! allbetzoff, I sent you a private message also.
Post by catmandewe on Mar 29, 2022 16:51:02 GMT -5
Post by hummingbirdstones on Mar 29, 2022 17:36:11 GMT -5
My pleasure!
geezer
Post by geezer on Apr 7, 2022 9:34:21 GMT -5
Got mine! looks like decent tumbling rough!
howgneiss
Member since May 2022
Post by howgneiss on May 23, 2022 20:58:28 GMT -5
Do you have any left?
Post by hummingbirdstones on May 23, 2022 21:50:45 GMT -5
