lunker
Member since April 2021
Post by lunker on Oct 5, 2021 16:58:56 GMT -5
Post by mohs on Oct 5, 2021 17:04:58 GMT -5
rock'n!
Post by MsAli on Oct 5, 2021 17:21:34 GMT -5
Great job! You should be pretty proud of that!
Post by jasoninsd on Oct 5, 2021 18:02:38 GMT -5
Way to go Lunk! I agree with Ali...you should be extremely proud with that one especially with it being your first! (There's no turning back now! LOL)
NDK
Post by NDK on Oct 5, 2021 18:59:15 GMT -5
That's a beauty, well done! lunker I'm a sucker for homemade equipment, how about a picture of the lap you built?
Post by opalpyrexia on Oct 5, 2021 20:18:55 GMT -5
Congratulations! Very nice cab.
Post by hummingbirdstones on Oct 5, 2021 20:48:49 GMT -5
Yay, lunker! Very nice and congrats on your first cab.
lunker
Post by lunker on Oct 5, 2021 21:15:04 GMT -5
Thanks everyone for the encouraging words. I am pretty proud of myself and my little cab. I made another one today. I thought it was green jasper but I think jasoninsd is right about it being bloodstone. And here is the equipment
Post by Pat on Oct 5, 2021 21:22:05 GMT -5
Congratulations! Very nice cabs. 👍🏻
fencejumper
Member since May 2021
Post by fencejumper on Oct 5, 2021 21:26:25 GMT -5
That is super nice! Bravo!!
Post by jasoninsd on Oct 5, 2021 21:32:12 GMT -5
Another "Way to Go!" Lunk! Really sweet work on your second ever cab! This is not me dogging you or the cab...just adding some things to think about. Can you see the flat spot on the top of the Bloodstone? All you need to do is work the angle of the edges a bit, so they eliminate that flat spot. Basically, a "steeper" angle going toward the center of the cab...that way you get an even semicircular dome, rather than a flat spot. Sometimes when I get a flat spot, it's easier for me to work from the center of the flat spot and work the cab in tiny circles - working from the center outward and then down toward the girdle line in order to eliminate the flat spot. This works for me when the flat spot is small...
Post by stephan on Oct 5, 2021 23:22:47 GMT -5
Nicely done. Next, you’ll be entering the monthly contest.
Post by fernwood on Oct 6, 2021 4:10:24 GMT -5
Nice cabs and equipment.
NDK
Post by NDK on Oct 6, 2021 8:50:50 GMT -5
Cool lap build! Just please be sure it's on a GFI and there's no water seeping down into the grinder motor 👍
Post by holajonathan on Oct 6, 2021 10:19:04 GMT -5
Good dome on your first cab. It took me 50 to get that good of a dome, and I still end up with flat spots unless I pay close attention. The best advice I learned about making cabs -- from a number of people on RTH -- is that a well shaped dome is the most important part. I agree. A good dome + a good polish makes almost any rock look like a gem.
You and I both had quite a bit of experience tumbling rocks before trying to make cabs. And from your tumbling results, you are obviously attentive to the process. In my experience, that flattened the cabbing learning curve a little bit, although I still have a long way to go.
Keep sharing your progress!
Post by Starguy on Oct 6, 2021 11:55:14 GMT -5
Nice polish.
Post by Tommy on Oct 6, 2021 12:33:17 GMT -5
Good job lunker! You're off to a great start.
Post by victor1941 on Oct 7, 2021 11:34:02 GMT -5
Good job on your first cabs. Is the polishing head on a drill or drill press?
Post by rockjunquie on Oct 7, 2021 15:32:21 GMT -5
Where there is a will; there is a way. Good for you! Those look very good for your first two. Bloodstone is a bloody hard stone and slow to work.
Post by MsAli on Oct 7, 2021 15:32:42 GMT -5
That is a really awesome build
Both Jason regarding the cab and NDK (Nate) regarding electricity gave some good advice.
