Post by holajonathan on Jan 7, 2022 13:32:28 GMT -5
Post by knave on Jan 7, 2022 13:35:57 GMT -5
It’s beautiful. I have a tip for focus. At least for a phone. Find what it is focusing on (like fingers) and move away a couple inches to get the focal point to move then snap the shot before it recalibrates.
Post by holajonathan on Jan 7, 2022 13:43:22 GMT -5
It’s beautiful. I have a tip for focus. At least for a phone. Find what it is focusing on (like fingers) and move away a couple inches to get the focal point to move then snap the shot before it recalibrates. Good idea! Thanks.
Post by miket on Jan 7, 2022 13:52:05 GMT -5
I like it, very interesting shape!
Post by holajonathan on Jan 7, 2022 14:00:14 GMT -5
My idea for the shape was a necklace with two bails, like this:
Post by knave on Jan 7, 2022 14:04:45 GMT -5
It’s very well done. Too bad about the fracture. But it’s still a work of art.
Post by holajonathan on Jan 7, 2022 14:08:19 GMT -5
It’s very well done. Too bad about the fracture. But it’s still a work of art. I knew it was there (the fracture), but it looked well healed. The moral of the story is -- assume Montana agate fractures are going to "open up" when cabbing, especially those that break the surface at a shallow angle. The fractures that are 90 degrees to the surface either stay closed or snap in half, but they don't seem to get chippy and ugly like this one.
Post by rockjunquie on Jan 7, 2022 16:39:13 GMT -5
Way to go! I love it! Too bad about the fracture, but I bet it was a good exercise. Yeah, that shape is template bound.
Post by holajonathan on Jan 7, 2022 17:07:06 GMT -5
Way to go! I love it! Too bad about the fracture, but I bet it was a good exercise. Yeah, that shape is template bound. It was a good exercise in yelling swear words that I haven't used in years. The fracture was practically invisible until the 3000 grit wheel That wheel is still rough after a couple hundred cabs. I am happy that it is going to last a long time, but I like my silky smooth 600 and 1200 Nova wheels better. My 600 wheel needs replaced soon, as I can see black patches where all of the resin has worn off. But it is so smooth and cushy, I am going to keep using it until I wear through the belt.
Post by perkins17 on Jan 7, 2022 19:01:13 GMT -5
Great cab! I love the shape and curves. That's too bad their a fracture. It looks amazing to me.
Post by hummingbirdstones on Jan 7, 2022 19:50:24 GMT -5
I like it! Unusual shape and your necklace idea for it is spot on. Definitely a template shape.
Post by drocknut on Jan 7, 2022 19:55:46 GMT -5
Very interesting shape and great cab even with a fracture.
Post by jasoninsd on Jan 7, 2022 20:13:40 GMT -5
What's next? A tridecagon?
How frustrating to put the amount of time into the cab for the fracture to appear at that late stage!
Definitely an awesome choice for a shape...and one you should keep as a template.
Post by holajonathan on Jan 7, 2022 21:08:52 GMT -5
What's next? A tridecagon? How frustrating to put the amount of time into the cab for the fracture to appear at that late stage! Definitely an awesome choice for a shape...and one you should keep as a template. I had to look up tridecagon. Now I know it means a 13-gon. I'll try one if you can find me a tridecagon template.
Post by holajonathan on Jan 7, 2022 21:12:00 GMT -5
jasoninsdI see you've been lobbying for a tridecagon cab for over a year... First hereAnd more recently, here
Post by jasoninsd on Jan 7, 2022 21:13:31 GMT -5
What's next? A tridecagon? How frustrating to put the amount of time into the cab for the fracture to appear at that late stage! Definitely an awesome choice for a shape...and one you should keep as a template. I had to look up tridecagon. Now I know that mean a 13-gon. I'll try one if you can find me a tridecagon template.
Post by jasoninsd on Jan 7, 2022 21:14:36 GMT -5
jasoninsd I see you've been lobbying for a tridecagon cab for over a year... First hereAnd more recently, here I keep waiting for someone to get one done...I sure as heck ain't gonna try it!
adrian65
Member since February 2007
Post by adrian65 on Jan 7, 2022 23:55:50 GMT -5
Ouch! So pitty you have that fracture on that gorgeous cab! You should have stopped the work when you noticed it, or did it show only at the end?
Adrian
Post by stephan on Jan 9, 2022 13:46:08 GMT -5
jasoninsd I see you've been lobbying for a tridecagon cab for over a year... First hereAnd more recently, here I keep waiting for someone to get one done...I sure as heck ain't gonna try it! What’s wrong? Triskaidekaphobia? Triskaidekagonaphobia?
Post by holajonathan on Jan 9, 2022 13:55:57 GMT -5
Ouch! So pitty you have that fracture on that gorgeous cab! You should have stopped the work when you noticed it, or did it show only at the end? Adrian The fracture was well hidden until the 3000 grit resin wheel. That wheels seemed to drive a very fine slurry into the crack and "open" it up. I was almost done at that point, so I finished it despite the fracture. I knew the fracture was there, and I had been careful to sand and grind in the direction that would not drive slurry into the crack. I think I screwed up on the 3000 wheel, went in the other direction, and that is when it got ugly... In hindsight I should have given up at that point, since polishing this shape with cerium ended up being time consuming. I resorted to a tiny buffing wheel on a variable speed dremel tool. I normally do final polish on a flat lap with leather + cerium, but there was no way to hit the inside curves on a flat lap.
