Post by holajonathan on Feb 10, 2022 14:47:14 GMT -5
Montana Moss Agate A full 1/4" (6.35mm) Around 5.5mm Around 4.5mm I know which one I prefer
Post by rockjunquie on Feb 10, 2022 15:48:12 GMT -5
Interesting. I like the middle one. I'm probably the odd man out again- as usual.
Post by holajonathan on Feb 10, 2022 16:09:52 GMT -5
Interesting. I like the middle one. I'm probably the odd man out again- as usual. I didn't say which was best, although if you assumed that I like the thinner better, you're right. A lot of MT agates look transparent (colorless) when cut thin enough, look blue when cut at a certain thickness, and look colorless but opaque when thick enough. So besides the issue of how well you can see the moss / plumes, color changes as well. Cutting angle effects this too, since MT agates usually have bands even though you can't see them unless back lit. The bands are more transparent from some angles than others. Lots to think about when cutting.
Post by rockjunquie on Feb 10, 2022 16:14:31 GMT -5
Interesting. I like the middle one. I'm probably the odd man out again- as usual. I didn't say which was best, although if you assumed that I like the thinner better, you're right. A lot of MT agates look transparent (colorless) when cut thin enough, look blue when cut at a certain thickness, and look colorless but opaque when thick enough. So besides the issue of how well you can see the moss / plumes, color changes as well. Cutting angle effects this too, since MT agates usually have bands even though you can't see them unless back lit. The bands are more transparent from some angles than others. Lots to think about when cutting. Yes, I did assume you liked the thinner one better. I don't know if it's just the pictures, but the thinner one looks much more busy with too much competing with the moss.
Post by stardiamond on Feb 10, 2022 17:57:51 GMT -5
HJ, you know your Montana but I don't understand what you are saying other the thinner the slab, the more light passes through it. The thickness of the slab changes the amount of attributes in it. A thick slab with a lot of dendrites won't have the spacing between them. I do a poor job some of the time getting a 1/4 inch and usually want to err to the thick side. A preform can be subtracted from but not added to. Here's an atypical Montana where the grinding dictated the pattern, not the original slab thickness.
Post by holajonathan on Feb 10, 2022 18:33:29 GMT -5
... I don't understand what you are saying other the thinner the slab, the more light passes through it... That's it. You already know. Good. But I bet there's someone on RTH who hasn't cut as many rocks as you and might not be aware that experimenting with thickness can be especially important with moss and plume agates. My photos offer an example of how much the appearance can change with very small differences in slab thickness. Yes -- more light passes through a thinner slab, but thickness also changes perceived colors, the apparent density of the moss or plumes, etc... Tela thought I should post the photos to the forum so I did. Just trying to help others.
Post by jasoninsd on Feb 10, 2022 20:21:27 GMT -5
Well...I'm enough of a newbie that I appreciate threads like this! It's something I was noticing when I was working Graveyard Point Plume Agates. I know...this is about moss...not plumes! LOL - Kidding, I know it's the same concept. Anyway...I realized that I had cut some of my slabs far too thick. One of the issues I realized was the "waste" of the plumes. With the thicker cut slabs, half the plumes can't be seen...they're buried. So, with a thinner cut slab, I was conserving plumes for the next slab. Also with the thinner slab, as you pointed out, light penetrates better and I think it allows for the plumes to show up better. That was a really long-winded way of saying "I agree"! LOL
Post by holajonathan on Feb 10, 2022 20:56:27 GMT -5
jasoninsd Yep. Same applies to GPP. Stinking Water Plume is another good example: First at 0.25" thick: Then at 0.2" thick: And finally, at 0.165" thick:
Post by jasoninsd on Feb 10, 2022 21:01:03 GMT -5
jasoninsd Yep. Same applies to GPP. Stinking Water Plume is another good example: First at 0.25" thick: Then at 0.2" thick: And finally, at 0.165" thick: What a great visual to show there is a distinct difference amongst those three thicknesses!
Post by holajonathan on Feb 10, 2022 21:03:22 GMT -5
jasoninsd Yep. Same applies to GPP. Stinking Water Plume is another good example: First at 0.25" thick: Then at 0.2" thick: And finally, at 0.165" thick: What a great visual to show there is a distinct difference amongst those three thicknesses! Yeah, you've got to go under 0.2" thick if you want individual plumes and not plumes on top of plumes. I'm not sure what you do with a 0.165" thick cab, however, except make a doublet (my eventual plan for that little guy).
Post by stardiamond on Feb 10, 2022 21:18:33 GMT -5
Stinking Water comes in different qualities. Very clear agate with distinct plumes can be as thick as a brick.
Post by jasoninsd on Feb 10, 2022 21:29:57 GMT -5
Stinking Water comes in different qualities. Very clear agate with distinct plumes can be as thick as a brick. Aren't there "exceptions" to any rule? Wouldn't you agree that the VAST majority of the time, what Jonathan has been posting about here is very valid?
stuckinohio
Member since September 2021
Post by stuckinohio on Feb 10, 2022 21:50:01 GMT -5
But does the thinness of the slab impact how big you can go with a cab with material like this?
If you're making a cab with a biggish amount of surface area, I'd imagine the slimmer slabs might be more prone to cracking or spalling while cabbing, whereas thicker slabs might hold up better?
I like big cabs and I cannot lie.
Post by jasoninsd on Feb 10, 2022 22:19:42 GMT -5
But does the thinness of the slab impact how big you can go with a cab with material like this? If you're making a cab with a biggish amount of surface area, I'd imagine the slimmer slabs might be more prone to cracking or spalling while cabbing, whereas thicker slabs might hold up better? I like big cabs and I cannot lie. Okay...the last part made me chuckle! LOL I think if you're planning on making a belt buckle sized cab, then yes...you might have to worry making the cab too thin. However, with the vast majority of cabs a person would make, a thinner cab isn't going to be unstable. Instability would come from unseen (or seen) fractures in the stone - and thickness may or may not save that. You have to remember, most cabs are going to be put into a wire-wrap for a pendant, or a setting for a ring or pendant (etc.). If it's in a setting, stability is added from the setting. If it's a wire-wrapped pendant, like Jonathan told me not long ago: It'll be just fine unless you're in the middle of a bar fight...and then it might sustain some damage...but that would be expected! LOL
Post by holajonathan on Feb 10, 2022 22:32:11 GMT -5
But does the thinness of the slab impact how big you can go with a cab with material like this? If you're making a cab with a biggish amount of surface area, I'd imagine the slimmer slabs might be more prone to cracking or spalling while cabbing, whereas thicker slabs might hold up better? I like big cabs and I cannot lie. It depends on your skill level and experience, I suppose. Thinner slabs means lower dome cabs. No way around that. And a low dome on a big cab is more difficult than a high dome on a big cab, which is more difficult than a high dome on a small cab. It probably took me 100 cabs of experience before I could reliably put a low dome on a big cab, and it still doesn't always work out perfectly. I usually don't cab any material that is so unstable (fragil) than slab thickness would make a difference in terms of what the cab cracks. A very thin slice of a solid agate -- say 1/8" thick -- is incredibly strong as long as you don't drop it. Good questions.
Post by holajonathan on Feb 10, 2022 22:40:11 GMT -5
Stinking Water comes in different qualities. Very clear agate with distinct plumes can be as thick as a brick. Are you saying there are brick thick Stinking Water agates where you can distinguish individual plumes throughout the brick-thick depth when back lit? Even if the agate part is very clear (which mine is, by the way, although my photos show dry slabs with saw-scuffed surfaces) aren't you still going to see plumes on top of plumes? Please share a photo of such material if you have it.
Post by holajonathan on Feb 10, 2022 22:54:24 GMT -5
Post by stardiamond on Feb 10, 2022 23:15:55 GMT -5
Stinking Water comes in different qualities. Very clear agate with distinct plumes can be as thick as a brick. Aren't there "exceptions" to any rule? Wouldn't you agree that the VAST majority of the time, what Jonathan has been posting about here is very valid? What he posted is standard. When I buy or choose material from what I have I try for the exceptions. Thinning a slab is a compensation and everyone needs to do it sometimes.
Post by jasoninsd on Feb 10, 2022 23:33:28 GMT -5
Aren't there "exceptions" to any rule? Wouldn't you agree that the VAST majority of the time, what Jonathan has been posting about here is very valid? What he posted is standard. When I buy or choose material from what I have I try for the exceptions. Thinning a slab is a compensation and everyone needs to do it sometimes. I guess I don't see where he posted anything that was "standard" other than the first 1/4" cut slab - which is pretty much understood as industry "standard" for thickness of slabs. If a person isn't cutting their own slabs, then yes, they can "thin" their cab to obtain whatever effect they're going for. Jonathan was trying to show examples for people who DO cut their own slabs. He was giving extremely good advice with regards to something "newbies" should be thinking about or considering when they're choosing their depth of cut on certain materials. If all material were cut "standard" and then thinning their cabs, they're just wasting material! If the slab were cut right from the start to the thickness - or thinness required for the desired effect, then "thinning" the cab isn't necessary.
Post by stardiamond on Feb 10, 2022 23:37:26 GMT -5
What I meant was that it was standard advice.
