Post by bobby1 on Dec 12, 2007 9:58:38 GMT -5
I noticed some discussion on the ID heading and I thought I would post some pictures of what can be done with Obsidian. If you cut Davis Creek Obsidian parallel with the color layers you can see band of "fiberous" color. If you cut a high (1/2") cab, high dome, long and narrow with these "fibers" across the cab, you can get an eye effect. Here is a bracelet that I made with some red layered Davis Creek material. Here is a large piece that has green layers. Here is a cab from the green material. Here is a small slab with an unusual pattern. Here are two pictures of things that I have made with Obsidian. As you may have noticed, Obsidian is one of my favorite materials to work. Bob
Post by bobby1 on Dec 12, 2007 10:01:40 GMT -5
OOPS! I got two pictures of the same thing. Here is the other picture that I meant to post. Bob
huffstuff
Member since August 2007
Post by huffstuff on Dec 12, 2007 10:29:59 GMT -5
OK, I just fell out of my chair! Anyone else?
I didn't know obsidian had so many variations! And your work is beautiful.
bouldergal
Glacier Meadow
Member since July 2007
Post by bouldergal on Dec 12, 2007 10:56:37 GMT -5
What gorgeous work. I have some obsidian I collected last summer. Maybe I ought to try doing something. I was afraid of it shattering. Thanks for sharing!
Post by Titania on Dec 12, 2007 11:06:08 GMT -5
VERY nice! I really, really love the organic feel of your work. And those cabs are just jawdropping!
Post by midnightrocksi3 on Dec 12, 2007 11:44:27 GMT -5
Thanks Bob! ;D
I must say you are a Genius when it comes to making Art and knowing your Rocks. I don't see much work on obsidian at all actually except for tumbled.. and I happen to love the color and that material as well. I totally dig your work, and you make every piece look pro. I'm talking like some rare stone from a far off land that has been lost .oh. sorry (wild imagination) What's cool is it's obsidian.. Thanks for the examples I've been wanting to know and see more .. I know agate is like the "in" thing and I appreciate the variety you've just brought! AND THAT BRACELET IS EYE POPPING! very classy And I'm curious do you do more like those? I can't even pick a favorite but I know now not to be hesitant to keep trying or collecting obsidian.. Gorgeous work.. Thanks again!
;D Roxy
Post by Tweetiepy on Dec 12, 2007 13:33:58 GMT -5
WOW - how I love obsidian...
The green obsidian, may (I'm not sure if there is just green obsidian) it looks to be rainbow obsidian, do you get different colors at a different angle?
the obsidian projects are awesome!
adrian65
Member since February 2007
Post by adrian65 on Dec 12, 2007 13:44:55 GMT -5
Is the metal work also yours? If so, you're a complete first class artist. Thank you for sharing your work with us! That bracelet is beyond imagination.
Adrian
Post by BuiltonRock on Dec 12, 2007 17:20:17 GMT -5
I like obsidian too! I have really only worked mahogany but it looked great! Not as good as your though. john
Post by bobby1 on Dec 12, 2007 17:20:18 GMT -5
The obsidian from Davis Creek is usually rainbow, but on occasion single colors in a piece do occur. Usually the single color is red, but in this case it is for the most part green. As you can see from the example, this piece isn't exclusively green, there are a couple of thin bands of blue. Yes, I do the metalwork. In these pieces it is gold plated silver (vermiel). Thank you all for the accolades! Bob
Post by midnightrocksi3 on Dec 12, 2007 17:56:32 GMT -5
Hey Bob .. How do you get your sphere so perfect?? man I love that piece.. it takes that entire piece on the edge of mystical yet old century style.. or something.. But how do you get that sphere so perfect looking..??
Roxy
Post by Sabre52 on Dec 12, 2007 18:11:30 GMT -5
Wow those cabs are so nice you make me want to try cabbing some obsidian again! Great rainbow obsidian too. I went by the digs but was hunting so didn't have any tools with me. Now I wish I hunted some. That looks even nice than some Mexican material I purchased!....Mel
AgateHeaven
Member since September 2007
Post by AgateHeaven on Dec 12, 2007 22:27:17 GMT -5
Whoa! awesome ...totally inspiring! thanks for sharing
Post by bobby1 on Dec 12, 2007 22:57:09 GMT -5
The process that I use to make the small spheres (marbles) is this: 1. Use the trim saw to cut a cube at the size that you want the sphere to be. 2. Grind the sphere as round as you can get it by hand. Making the tool: I made some devices from a 1/4-20 screw and pieces of round steel shaft material. On a metal lathe drill and tap a hole in one end of the steel shaft and screw the screw into the hole. Cut the screw at 3/4" length. Using a large 1" drill bit and drill a depression into the other end of the steel shaft. I screw this device into the center hole where the mounting screw is on a flat lap., thus the depression is pointing upward. The diameter of the tool (cup)must be no more than 3/4ths of the diameter of the sphere to be made. I made multiple sizes of this cup for various sizes of spheres. Here are pictures of the cup. 3. With the preformed sphere in your hand (always wear gloves because the grit will stain your hands black), dip it into water and into 220 grit tumbling grit. With the cup spinning , hold it in the cup and rotate it in all directions. As the grit wears down keep dipping it into the water and grit and rotating it in the spinning cup. When the sphere is perfectly round (frequently wash and dry it to inspect for any remaining flat spots) wash the sphere and cup and go to 400 grit. When the 220 grit pits are removed, go to 600 grit. If you want to go to a finer grit the polishing will go faster. Here are pictures of the sphere and the cup. 4. Thoroughly wash the sphere and your hands and dop the sphere. 5. Polish the exposed side. Redop the sphere to get all sides polished. I hope this wasn't too lengthy or babbling too much. Bob y
Post by stonesthatrock on Dec 12, 2007 23:21:30 GMT -5
wow, wow and wow again. You work is unbelievabe. so beautiful
Post by midnightrocksi3 on Dec 12, 2007 23:26:19 GMT -5
NOOOO WAAAY!! THAT WAS GENIUS!!! Wow.. I've got to learn to ask more questions like this one!!! lol Thank you so much.. One of these days I'm going to be able to show off my stuff. And I'm so glad I got it from a Pro.. !!! *smiles* Roxy
Post by Deleted on Dec 13, 2007 0:02:58 GMT -5
I recently went to visit Bob and to say he is a expert is a understatement. For the hour at his home he gave me lessons in rock tumbling, opal doublet and triplet making, how to stabilize different rocks, polishing jade and other polishing techniques. He also gave me some of this awesome Davis creek obsidian & some opal triplet preforms. Oh and I forgot to mention he is a heck of a nice guy too!
Post by LCARS on Dec 13, 2007 0:26:39 GMT -5
I'm trying not to swear but that is some really #@&$%! nice work! That second obelisk almost made me ruin another perfectly good keyboard. ;D
SteveHolmes
Member since July 2009
Post by SteveHolmes on Dec 13, 2007 7:37:37 GMT -5
Beautiful Work! That bracelet is so unique and love that Green Cab. Thanks for sharing your stuff with us. The tutorial is so informative too. What an Art! Steve
Post by rockyraccoon on Dec 13, 2007 10:16:55 GMT -5
great work!
kim
