Post by jamesp on Oct 9, 2014 8:25:45 GMT -5
Build and sell fire pits. The basic design burns slow and is hard to start a fire in due to a lack of draft. And they are smoky for the same reason. So those sitting around it get smoked. Tried all kind of bottom vents to no avail. This trick turned it into an incinerator, even burning dampish leaves. some construction tip tricks- Lazy Susan rotates by force of wire wheel: Guide for surgical tool, the plasma cutter, cut made by rotating Lazy Susan: Surgery complete: Grinder force also rotates table: Lazy smokey fire in fire pit: Add turbo cap: So as the heat rises thru the center hole the air gets drawn in around the gap around the edge of the cap creating draft on to the coals. This creates an air flow that turns into a well fed fire. Smoke lifted well away by the torch effect. It does increase the amount of fuel needed quite a bit. But result fairly dramatic. Gets hot. Scott, I am thinking about you, should you want a real torch, pour a cup of kerosine into the center hole. Or even used motor oil will ignite and burn off completely and cleanly. Great application for a used motor oil drip burner. Will see if cap gets cherry red in the dark tonight.
panamark
Member since September 2012
Post by panamark on Oct 9, 2014 8:58:29 GMT -5
Brilliant. And great execution.
Post by Fossilman on Oct 9, 2014 9:07:02 GMT -5
James builds "FIRE"!!!!!! Nice idea buddy............
Post by jamesp on Oct 9, 2014 9:08:23 GMT -5
Brilliant. And great execution. Will see how it sells Mark. Just put it on Etsy. Thanks
Post by jamesp on Oct 9, 2014 9:11:01 GMT -5
James builds "FIRE"!!!!!! Nice idea buddy............ I figure you have sat in front of a campfire a few times Michael in Dakota and Montana. Does this make sense to you ?
Post by Fossilman on Oct 9, 2014 10:15:03 GMT -5
Yes it does James.................As the old saying goes,"If I had a dollar for every time"..LOL We do that here in Oregon too,at my brother in laws home in his back yard...
Post by jamesp on Oct 9, 2014 10:27:30 GMT -5
Yes it does James.................As the old saying goes,"If I had a dollar for every time"..LOL We do that here in Oregon too,at my brother in laws home in his back yard... Beer drinkers like them, dehydrates em for the next round.
grayfingers
Member since November 2007
Post by grayfingers on Oct 9, 2014 11:08:30 GMT -5
Dang James, put a bellows on that and you will have a forge!! Very nice idea. Would make a quick pot of coffee.
adrian65
Member since February 2007
Post by adrian65 on Oct 9, 2014 11:36:19 GMT -5
Great idea! You should weld two handles to the turbo cap to be able to remove it while hot, otherwise the grilling area would be limited to the hole in that turbo cap.
Adrian
Post by mohs on Oct 9, 2014 12:28:38 GMT -5
I want one over my eternal resting place ala' JFK eternal flame hot~rip
excellent bright idea
Post by jamesp on Oct 9, 2014 12:42:03 GMT -5
It could be put over a camp fire and get the same result. Maybe a square one to serve as a cooking surface. Flow may be hindered tough. Yes Adrian, handles perfect, or a hinge and a handle.
Post by jamesp on Oct 9, 2014 12:46:52 GMT -5
Dang James, put a bellows on that and you will have a forge!! Very nice idea. Would make a quick pot of coffee. Smaller hole creates more velocity Bill. And it sounds like a tornado.
Post by jamesp on Oct 9, 2014 12:48:32 GMT -5
I want one over my eternal resting place ala' JFK eternal flame hot~rip excellent bright idea I don't know about being buried under it Ed, they may think it is the tip of a nuclear warhead.
Post by mohs on Oct 9, 2014 13:17:28 GMT -5
I want to go up in a mushroom m :Dstly
Post by rockpickerforever on Oct 9, 2014 13:21:38 GMT -5
I'm gonna bet that turbo cap DOES glow red hot tonight, especially if you get that puppy stoked. Cool idea, so long as it doesn't melt down.
Can get your face sunburned at night!
Post by jamesp on Oct 9, 2014 14:16:52 GMT -5
I'm gonna bet that turbo cap DOES glow red hot tonight, especially if you get that puppy stoked. Cool idea, so long as it doesn't melt down. Can get your face sunburned at night! Used motor oil gets it HOT. I capped the drain so it all burned off. Ever heard of a used motor oil drip furnace? Good application. It is mild steel, not likely to get hot enough.
Post by Pat on Oct 9, 2014 17:45:45 GMT -5
Wow! Great idea to avoid smoking those around the fire. I gave up bbqing outside because the smoke hurt my eyes.
A small version of that would be nice, too; they are also attractive.
Post by jamesp on Oct 9, 2014 18:23:25 GMT -5
Wow! Great idea to avoid smoking those around the fire. I gave up bbqing outside because the smoke hurt my eyes. A small version of that would be nice, too; they are also attractive. Were you cooking on a common back yard type grill Pat ? The smoke is tricky to control on those. The sugar and spices from the sauce can do a number on the eyes in particular. Some woods are worse than others too.
spiritstone
Member since August 2014
Post by spiritstone on Oct 9, 2014 18:44:04 GMT -5
Similar idea to a Rocket stove. Burns hotter with less smoke.
Post by Pat on Oct 9, 2014 19:16:06 GMT -5
@sjamesp it was a big gas burning grill with charcoal. The smoke seemed to have a magnetic attraction to me no matter where I stood.
I didn't know that the sugar and spices, or the wood had anything to do with it. I figured it was how the wind blew and that magnetic attraction!
