Shaping Cabs On A Trim Saw...That's Crazy Talk! - Updated Pics 11/19/21
Nov 20, 2021 20:47:42 GMT -5
rockjunquie, 1dave, and 2 more like this
Post by jasoninsd on Nov 20, 2021 20:47:42 GMT -5
I can rough grind a dome just as fast (and maybe faster) with a new 60 or 80 grit lap disc. But the lap disc will only grind really fast for about 15-20 hard (agate) cabs, before it starts slowing down. After 30 or 40 cabs, it might take me 30-45 minutes to grind a dome on my Ameritool 8" flap lap. Performance seems to plateau around there for a while, and after a few hundred cabs (or the equivalent amount of grinding specimen / tumbles) it will start getting slower and slower. That is when I consider it worn out and replace it. These times and numbers will obviously vary based on the quality of the disc, the lap speed, how much pressure you apply, the type of stone, etc... But they are estimates based on my personal experience.
Same goes for a new 60 or 80 grit cabbing wheel. They grinder super fast for a while, level off for a long plateau, and the good ones (DP Galaxy, for example) never stop grinding, they just get very, very slow after years or use. I am talking about plated wheels, not sintered.
What is special about your saw blade is that it still grinds fast after having been used so much. I achieve similar results with a sintered cabbing wheel by dressing it frequently to expose new diamonds. The sintered wheels costs many times more than a trim saw size blade, making the blade grinding method an economical option.
Finally, if it takes 2 hours to dome anything on your slab cabber, you need a new lap disc. Or try lightly running a dressing stick over the face to wear off a tiny bit of the metal plating. You aren't really supposed to dress plated wheels / discs, but it's worth a shot if it's otherwise going into retirement.
So, today was a day of discovery. My 80 grit disk is absolutely shot...gone...done for...needs replacement!
I knew my 180 was seeming a bit aggressive lately, so I decided to try shaping some cabs with the 180 rather than the 80. I hadn't bothered trying this as I started out with the 180 originally...and thought it cut slow, which is why I ended up getting the 80. I've been using the 180 on slow speed just to get rid of the 80 scratches. Anyway, I went full throttle today and shaped a bunch of cabs...and it was cutting like a hot knife through butter compared to how my 80 has been grinding.
I did take a dressing stick to the 80 grit to see if I could get it working any better. And I did see a slight...and mean VERY slight improvement. So, I know without a doubt I need to get a new coarse disk. I'll go back through our messages and see if you said where you got those disks from...
Of course it is! My neck is as red as yours brother!
I do think I need to start doing a better job at cleaning the disks like this after each use. I have noticed buildup...but I didn't think it was effecting things. Thanks for posting this Robin!
And I do think getting a new 80 or 60 grit disk is a better solution to using the saw...just sayin'...
