AzRockGeek
Member since September 2016
Post by AzRockGeek on Apr 10, 2022 15:23:42 GMT -5
I was cleaning the shed and ran across a few things you don't see much anymore, what is your rock shed hiding? A NOS congo 12" blade Can of diamond saw lube. A few cans of unopened lortone tumbling supplies.
hummingbirdstones2
Vince A., 1958-2023
Member since August 2018
Post by hummingbirdstones2 on Apr 10, 2022 22:05:12 GMT -5
Here's one to go with your Diamond Lube shown above.
Note that there are no zip codes on the Bruce products or the Congo blade.
EDIT - Have a few old saw blades here, too. Mostly 6". I think one is "new", or at least close to it.
hummingbirdstones2
Vince A., 1958-2023
Post by hummingbirdstones2 on Apr 10, 2022 22:19:58 GMT -5
Vertical lap with four laps (two on other side) that we never got an ID on. Didn't match old Diamond Devil or other models we could find.
Has a sticker on it that says "Gates Polyflex Belts Used On This Machine" but could find no other ID plates or labels.
Post by hummingbirdstones on Apr 10, 2022 22:49:31 GMT -5
Wood spool polisher. They still make these, but with phenolic spools.
aGates
Building a silver studio
Member since January 2021
Post by aGates on Apr 11, 2022 7:06:22 GMT -5
the wood polisher ive aeen people rave about for jade polishing. i dunno but its cool.
Post by perkins17 on Apr 11, 2022 9:14:03 GMT -5
the wood polisher I've seen people rave about for jade polishing. i dunno but its cool. I actually just did some jade on one Saturday. I can confirm they work great for it!
Post by rmf on Apr 11, 2022 12:27:21 GMT -5
hummingbirdstones I use a spool polisher for Star Rubies and Sapphires. It does a superior job to my titan. Rough on Titan grind to 600 then spool polish the rest of the way.
gemfeller
Member since June 2011
Post by gemfeller on Apr 11, 2022 13:44:15 GMT -5
Wood spool polisher. They still make these, but with phenolic spools. If I ever get back into cutting star garnets I may borrow that little machine. It's perfect for preventing heat spalling while sanding and polishing garnets. Great for opals too.
AzRockGeek
Post by AzRockGeek on Apr 11, 2022 14:45:42 GMT -5
hummingbirdstones I use a spool polisher for Star Rubies and Sapphires. It does a superior job to my titan. Rough on Titan grind to 600 then spool polish the rest of the way. How do you charge the spool with the diamond and how long does it last? I always heard good things about these polishers.
hummingbirdstones2
Vince A., 1958-2023
Post by hummingbirdstones2 on Apr 11, 2022 20:12:12 GMT -5
Diamond paste worked into the surface with a cab will do for charging it.
Post by hummingbirdstones on Apr 11, 2022 21:31:02 GMT -5
Wood spool polisher. They still make these, but with phenolic spools. If I ever get back into cutting star garnets I may borrow that little machine. It's perfect for preventing heat spalling while sanding and polishing garnets. Great for opals too. Rick, you are more than welcome to borrow it anytime you want!
Post by rmf on Apr 13, 2022 14:37:22 GMT -5
hummingbirdstones I use a spool polisher for Star Rubies and Sapphires. It does a superior job to my titan. Rough on Titan grind to 600 then spool polish the rest of the way. How do you charge the spool with the diamond and how long does it last? I always heard good things about these polishers. I just use a little dab on the stone and use it to push it into the maple. Originally I had a phenolic unit but I bought a collection that had an old one with maple and I liked it better. I sold the phenolic unit when I had a chance. I use mineral oil as extender. I use Mountain Mist diamond which is suppose to have higher diamond content paste. Works well but slow.
quartzilla
Member since April 2020
Post by quartzilla on Apr 13, 2022 18:33:43 GMT -5
Wood spool polisher. They still make these, but with phenolic spools. Never seen one of these before or knew of their existence! Pretty awesome! I guess you really can learn something new every day.
Post by quartz on Apr 16, 2022 14:24:51 GMT -5
I have two of those wood spool polishers I'd rather someone else had, likely never get to use them because of wife's health problems; I'm the only caregiver.
Post by quartz on Apr 16, 2022 14:32:50 GMT -5
Hope this thread brings out a bunch of fun things, thought I'd put mine up while it's raining. My wife found this at an estate sale, $7.50, seller said won't run because of "cold belt", motor runs fine with a bit of oil but the belt shredded. 20/20 hindsight says I should have given the barrel dimensions: 6 3/4" hex, 4" deep, translates to .72 gallon or ~8-8 1/2 pound capacity. A little hard to read, price is/was $2.79
Post by perkins17 on Apr 16, 2022 16:51:07 GMT -5
This is a cool thread! I've been meaning to put some of my old stuff in but just got around to it. A 1970's fully functioning Diamond Pacific Pixie: IMG_20220313_102118219 by Perkins17, on Flickr An old Raytech 15 inch vibrating flat lap I need to get some parts for: IMG_20220416_144254486 by Perkins17, on Flickr A custom technologies industries MT-4 (now Diamond Pacific): IMG_20220416_144338085 by Perkins17, on Flickr These are all "working class" machines in my shop, and work as well as the day they were bought. Thanks for looking!
AzRockGeek
Post by AzRockGeek on Apr 16, 2022 16:55:30 GMT -5
I like the old pixie, never seen one like it.
AzRockGeek
Post by AzRockGeek on Apr 16, 2022 17:00:35 GMT -5
Post by Rockoonz on Apr 16, 2022 20:43:38 GMT -5
Here's my old HP trim saw, not sure exactly how old but it's in the 1947 HP catalog on the Cigarbox rock site.
hummingbirdstones2
Vince A., 1958-2023
Post by hummingbirdstones2 on Apr 17, 2022 11:50:12 GMT -5
This one will also be in the running for the oldest survivors. A "Victor" 10" trim saw. I think Victor lapidary was bought by ?, then eventually by HP. Someone gave me a rundown on the corporate info years ago, but I can't seem to find it. If anyone has info we'd sure like to hear it.
This old critter is all cast aluminum, with press-fit bronze arbor bushings, and an adjustable-height blade guard.
